Question about Dyson Vacuums
Dyson Animal vertical portion won't snap back into place to remain vertical.
There's no suction coming from the carpet brush head. All suction going through the handle, like it's locked into place. Was working great but just stopped. Suggestions, please!
  • 5 Answers
SOURCE: dyson 18 losing suction
Check the HEPA filter if it has one. This bit of foam gets clogged over time and significantly reduces the suction especially if you've been vacuuming a lot of very dusty areas i.e. dust from building work etc. Just wash the filter with lots of water and leave to dry before reinserting.
Posted on Aug 12, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
  • 438 Answers
SOURCE: dyson dc07 animal\ no suction
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
Posted on Apr 04, 2010
SOURCE: The carpet brush on my
Next to the power switch is another button, this switches the brushbar on and off. The brushbar can be turned off for hard floor surfaces so as not to scratch them
Posted on Oct 25, 2010
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: suction only coming through the wand when its replaced its not switching back to the upright. I have a dyson DC28 animal
    Hi there, it's Jack at Dyson.
    I'm sorry to hear your DC28 doesn't seem to be working correctly. It sounds as though the change-over valve may be jammed - this diverts the suction to the hose when you remove the wand, and back to the cleaner head when you replace the wand on your machine.
    You may find a blockage is jamming the valve - you can check for this using our online Support guide:
    If you can't find any obstructions, please get in touch with us directly as we'd appreciate the opportunity to provide further assistance. If you email us at, we'll be in touch as soon as possible.
    Best wishes,
    Dyson Online Customer Support
    Posted on Dec 06, 2012
    Dyson Animal vertical portion won't lock into vertical position. However, all suction is going through the vertical portion...brush roller head isn't on at all.
    Theres a part on the side that is free to move when u pull machine down for using it diverts suction.sometimes they get stuck pull handle right down to floor level turn machine over and check on the side at hinge part
    Apr 15, 2017 | Dyson Vacuums
    Animal ball great on tiles but carnt push it on a thick carpet turn it off and it's fine but turned on no chance ,, get cheep vac out that's fine ,, head by the way not blocked all free
    Yes that's a nappy carpet verses long brushes, plus awesome suction. If you have a trigger to relieve suction a bit you will just have to nurse it. One direction of nap is always easier than the other. Eventually your Dyson will suck yourcarpet up, making it thinner, and the engine will tire and those long brushes will wear down and it will be just right
    Feb 06, 2017 | Dyson Vacuums
    Brand new dyson DC40 has no suction at bottom
    Hi Marin, it's Jack at Dyson.
    DC40 is a powerful mid-size Dyson upright vacuums, and we wouldn't expect you to have any concerns about performance on hard flooring or carpet. As long as the machine is used and maintained as described in the User guide we would not anticipate a change in performance, and we're on hand to help if Dyson owners need assistance.
    It's important to note that for effective pickup, the cleaner head needs to form a close seal with the floor surface. Simply placing a hand under the cleaner head does not give an accurate idea of suction as you're not creating a seal, as you would be when you place your hand right across the end of the wand or hose. If you turn on and recline the vacuum, turn off the brush bar then lower the cleaner head onto something like a sheet of newspaper, you should see the newspaper held tightly against the soleplate by the vacuum's powerful suction.
    We're keen to discuss this with you, and to help ensure your DC40 is working as well as it should be. Please email your full contact details to my colleagues at, and one of our experts will be in touch as soon as possible to provide further assistance.
    Feb 14, 2015 | Dyson DC40 Animal Upright Vacuum -...
    Dyson suction problem
    I'm sorry to hear you're having difficulties with your Dyson. If the cleaner won't pick up via the cleaner head and will not stand upright, the valve carriage needs realigning. This is simple to do - please follow the steps shown in the video below.
    This should resolve the issue, but for any further assistance or advice with your machine, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Dec 22, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
    Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Dyson Customer Service
    Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Suction loss when handle is tipped back to clean carpet
    can any one help,
    Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
    Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Vacuums Logo
    Top Dyson Vacuums Experts
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
