Question about Refrigerators
Ice maker has ice in tray., but dump and make anymore.
  • 833 Answers
SOURCE: Kenmore side by side 22 ice maker
I'm assuming you're speaking of the mechanism that froze/transported the ice to the bin. Try a tiny bit of vegatable oil spray like Pam. If you are speaking about ice in the ice container, this is caused by a partial thaw of the're opening the door too often.
Posted on Jun 19, 2008
  • 145 Answers
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
  • 1606 Answers
SOURCE: Ice maker quit dumping ice to the tray
You have a bad icemaker thermostat ( replace the whole icemaker ) or the temperature is not at least 5 degrees cold . You might check your coils to make sure they are clean (usually at the bottom from the front of the fridge ) only vacum or brush what you can get to as this will also keep the icemaker from harvesting .
Posted on Jul 11, 2009
  • 5 Answers
SOURCE: Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Posted on Oct 26, 2009
  • 112 Answers
SOURCE: ice maker not making ice. ice in the tray, but
Its the bar and gears that has frozen.
There is a stainless bar on the front of the ice maker. It move out and back to check for ice in the bucket. This bar is stuck and the ice maker thinks there is no need to harvest ice.
Try to move this bar and I bet it is stuck.
You can get a new Ice maker from Ebay and replace it yourself.
Posted on Jul 25, 2010
Ice maker makes ice but does not dump
The mechanism (motor) in the tray housing is bad. Trying to manually turn the tray to dump the ice can actually do the harm to the motor. Not advised. You'll need to buy a new Tray Assembly.
Jan 07, 2015 | Samsung RS2534 Side by Side Refrigerator
I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to...
Check for freezer temp - if it is not 10 degrees or below the ice maker thermostat will not turn the ice maker cycle on by removing the frozen ice in tray and then refilling it for next dump cycle. And if freezer temp is high you may have leaking door gasket, dirty condenser coils, improperly operating self defroster which raises temps, low refrigerant.
Aug 04, 2017 | GE Refrigerators
Could be an open circuit to the ice tray sensor. This is the wire under the ice tray. It is flexed during each cycle and can fatigue easily. I found this condition on a three year old unit. A simple solder repair and heat shrink tube corrected the problem.
Jul 26, 2012 | LG LFX25971ST Bottom Freezer French Door...
My ice maker was not dumping ice from the tray. I removed the ice maker and rinsed it with water. I allowed it to dry and reinstalled it and ice still would not dump. I did some research and found out they...
It sounds like the water inlet for your ice maker is now frozen. Blast a hair dryer around the waterinlet to the ice maker for 5-10 minutes, reconnect the ice-maker and you should hear the sweet sound of flowing water
Jan 25, 2011 | Whirlpool ED2FHEXN Side by Side...
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker has ice in the tray, but will not dump or do anything
"Ice in the tray". Do you mean ice is in the well of the ice maker, or in the tray or bucket that collects the harvested cubes from the ice maker?
If the problem is the ice is in the ice maker well, and will not dump, then, if the ice maker is turned on, and the temperature in the freezer is 14 degrees or colder then the ice maker has failed.
In rare occasions an ice maker can be repaired but is rarely done, and is a repair only someone with strong working knowledge of ice makers can perform.
If you are handy with tools you can remove the icemaker. 3 screws and power plug. Once out you can check the well to see if something has jammed up the rake, but that's about all.
Oct 28, 2009 | Maytag MSD2454G Side by Side Refrigerator
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Ice maker not dumping ice
The freezer has to reach a certain temp. in order to freeze ive. You might have to wait overnight for ive-- keep the freezer closed.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
