After an update yesterday system will not reboot. No display. Motherboard code stops with code 15.
2 Suggested Answers
SOURCE: Ps3 System Update Failed, PS3 boots with error code 8002F14E.
-Open the side of your PS3 where your HDD is. Take the screw out, but leave the HDD in.
-When the update begins, pull your HDD out of the slot. It will tell you an error occured and it tells you to restart your system and try again. Instead, let the count from 60 run out, your screen will go blank for about 30 seconds then it will start back up and tell you that your Hard Drive needs to be reformatted. If you do not get this msg after 30 seconds, do it again until it does! Now, slide your HDD into place again - (make sure your controller is PLUGGED IN) and press the white PS3 button on the controller. It will then ask you to either press start and select at same time OR white PS3 Button - PRESS START and SELECT. Do not agree to user agreements!! Simply hit cancel and it will kick back to the PS3 start up screen.
Posted on May 09, 2009
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
Motherboard, processor or Power Supply?
this is probably the hard drive
Dec 07, 2009 | Computers & Internet
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
No sound
i have ASUS P5GL MX Motherboard yesterday i installed win 7 ultimate so that i want display driver
Jun 02, 2009 | ASUS P5GL-MX Motherboard
Completley dead
i had the same problem with my psp i changed the motherboard and it works like
a new one again. another thing you can try is debrick it a new motherboard will
cost about $80.00 i hope this will help you
Dec 26, 2008 | Sony PlayStation Portable (PSP) Console
System shuts down after surfing the internet
Regarding the error code, all you need to do is update your driver. You can do this by downloading the most up to date driver from motorola here.
Unfortunately, it seems like this might be two seperate issues.
Sometimes machines, especially laptops but it will happen to desktops as well, will shutdown when they are overheated in an attempt to prevent damage to the physical hardware. Judging by the "after about 15 minutes" comment, I think this might have something to do with it as that 15 minute window would give a non-functioning fan or unventilated laptop enough time to overheat your machine.
If the driver update does not stop the random rebooting and you do not think the machine is hot when it reboots, do this:
right-click My Computer and choose Properties; click the Advanced tab. In Vista, click the Start button, type System, Properties, Advanced, and press Enter. Click Continue if prompted by User Account Control.
In all versions, click the Settings button under 'Startup and Recovery'. Uncheck the Automatically restart box, and click OK twice. The next time the problem occurs, instead of rebooting you will likely see a text screen reporting a system error. Report back with what error it gives you.
Nov 30, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Hanging problem
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Sep 03, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
David Payne
David Payne
