Question about Bosch Washing Machines
Bosch sms50e02uk won't fill. Error code 24e comes up checked pump clear and runs ok side panels off machine and cannot see water coming in
  • 1294 Answers
SOURCE: Drain pump runs constantly:Error code E02
Suggestions: First see that the exit hose behind your machine is inserted at a particular height, ie about 3 feet above ground level, then into the standpipe in your wall. If things dont work plug off the wall, open up behind, you will see a thin pipe coming down from the pressure switch to the drain area. Disconnect this pipe carefully from the top and blow into it, it should be free. If blocked clear, if broken or damaged change. Refit carefully.
Pl rate me helped.......
Posted on Dec 28, 2007
jason0110
  • 66 Answers
SOURCE: error code h20
hi sounds like a faulty fill valve easy fix
Posted on Sep 21, 2008
  • 409 Answers
SOURCE: bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Posted on Sep 25, 2008
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
  • 3230 Answers
SOURCE: Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Water light is on
The light can come for a few reasons. Not emptying, not filling, over filling or water leaking into base.
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left. Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Apr 10, 2013 | Bosch SGS45C02 Dishwasher
Bosch classixx dishwasher starts cycle then says " check water" and then seems to do same thing again and again, pumping water in and draining it again
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left (white plastic disc with two wire connection tag). Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Mar 09, 2013 | Bosch 24 in. SGS43C12 Classixx...
Check water light on my boach dishwasher
Feb 20, 2013 | Bosch Dishwashers
MACHINE WONT FILL WITH WATERAND THE WATERCHECH LIGHTS UP
Machine stopped mid cycle, won't spin or did not drain, no error code displayed, tried unplugged and restart. no luck
next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
Aug 15, 2011 | Maytag EPICz 3.7 Cu. Ft.
E1 error code on my kenwood dishwasher [kwd243a
Hi
The E1error code indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, it is much more likely to be flow meter .
Thanks for contacting fixya.com
Sep 10, 2009 | Dishwashers
Will not fill. Drain pump runs all the time.
Sounds like flood switch has been activated. They have a float in the base of machine, which will activate drain pump if a leak has occurred. Unplug from power- remove right hand side panel, check to see if any water in base. If so, leak has occurred. Clear water from base and test run to locate leak
Aug 08, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
