Question about Toyota Computers & Internet
Asin solid flywheel and clutch fitted to 2 litre toyota d4d diesel engine using toyota supplied bolts. What are torques required and do flywheel bolts require two stage torque procedures.
Have part numbers if required
3 Suggested Answers
SOURCE: Torque spec for flywheel bolt: Isuzu 2.5 diesel engine
normally 110 nueton metres. use nut lock and once you have torqued you will feel if you have to tighten it a bit more.
Posted on Aug 15, 2008
nobody322
  • 20706 Answers
SOURCE: Torque spec for flywheel bolt: Isuzu 3 ltr diesel engine
alldata.com
log in read?
Posted on May 09, 2015
I have a 94 Hyundai Excel. I am replacing the clutch but can't find the torque settings anywhere.
clutch/flywheel torque settings - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/...accent/146383-clutch-flywheel-torque-setti...
Aug 2, 2012 - 3 posts - ‎2 authors
Im after the torque setting for the clutch and fly wheel for a lc 2000 accent with the dohc 16v engine. cheers.Missing: .94
Torque value head bolts 1994 hyundai excel 1.5l - Fixya
www.fixya.com/cars/t12339610-torque_value_head_bolts_1994_hyundai
Apr 7, 2012 - SOURCE: torque settings for a hyundai accent 1500 1998. cylinder ...SOURCE: how d i change a clutch in a hyundai excel 1994. Hi first lift the ...
Flywheel & Pressure Plate Torque Specifications? - Hyundai ...
www.hyundaiaftermarket.org > ... > Engine, Intake, Exhaust
Dec 19, 2015 | Hyundai Cars & Trucks
Where are Cam and crankshaft timing marks on nadia d4d engine
follow this link for a video showing change of timing belt , this will show the timing marks etc
Toyota avensis D4D 2 litre diesel timing belt installation
May 04, 2015 | Cars & Trucks
Toyota 2c. I need cylinder head and flywheel Torque settings
Toyota 2c ...
USE NEW BOLTS...
Torque sequence:
You're driving a diesel single cylinder head engine. Engine head torque has to be done in specific order and stages if not can warp head or break bolts. Suggest you get torque sequence and torque specs from your Toyota dealer, they can give you correct answer. Don't trust answers on here, if you choose wrong specs. could end up messing up head.
Flywheel - Use a Sealer on bolt, Manual Transmission 88nm/65 ft lb... Auto Transmission 74nm/55 ft lb
Aug 06, 2014 | Cars & Trucks
HI HILUX SURF WITH 2LT DIESEL ENGINE CAN I GET CORRECT TORQE FOR. 1-TORQE FOR HEAD BOLT? 2-TORQE FOR CON ROD BEARING BOLT? 3-TORQE FOR MAIN BEARING BOLT?
Torque Settings Mains = 108NM
Big Ends = 54NM + 90° +90°
Flywheel = 122.5NM
Cylinder Head = 78 NM + 90° + 90°
Valve Settings
Exhaust = 0.40 mm - 0.50 mm
Intake = 0.20 - 0.3 0mm
Jun 30, 2011 | Toyota 4Runner Cars & Trucks
Grinding in tranny after replacing clutch
Did you remember to torque all of your clutch plate bolts? Flywheel bolts?
May 04, 2010 | 1996 Ford F250 Crew Cab
Isuzu trooper problem!with a 00 3 litre diesel engine not starting
Was it lined up right as the trigger point for the sensor is important.Is the fly wheel fitted one position only that the bolt holes line up or will it fit no matter which position it bolts up Line up the flywheel trigger with the sensor after you have put the engine to Top Dead Centre.Put at tdc and see if the trigger and sensor are together.
Oct 18, 2008 | 2000 Isuzu Trooper
Jul 27, 2008 | 1995 Isuzu Pickup
Computers & Internet Logo
26 people viewed this question
Top Toyota Computers & Internet Experts
David Payne
David Payne
Are you a Toyota Computer and Internet Expert? Answer questions, earn points and help others
