Question about Garden
How do you remove a spark plug on an Earthquake Vector tiller?
4 Suggested Answers
boscia
  • 163 Answers
SOURCE: older model earthquake rear tine tiller won't start
try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Posted on Nov 30, 2008
bunnydawg
  • 5158 Answers
SOURCE: I have an older earthquake
it is very likely water in the fuel. by a bottle of gas line antifreeze, it will soak up any water. add about a half bottle or slightly less. let it sit for about five minutes then try to restart it.
Posted on Jun 16, 2011
  • 51545 Answers
SOURCE: how to remove electric stater from a earthquake tiller
maybe this link will help you http://www.northerntool.com/images/downloads/manuals/261160.pdf
Posted on Apr 07, 2015
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
Earthquake Vector Compact Tiller Model#26750
Did you pull the spark plug and clean it, as well as the plug well and compression ring. Blow it out with canned air and dry before replacing the plug. Be certain the plug GAP is correct and it is free of carbon deposits. Rest the plug, tighten by hand and let her go. See if that fixes the problem.
Feb 27, 2014 | Earthquake Vector Compact Front Tine...
Tiller won't start. brand new
did you mix proper gas and oil. check or replace plug and check for spark
Apr 21, 2013 | Ardisam Inc Earthquake Mini Cultivator
How easy is it to replace clutch cable on earthquake mc 43 tiller
Remove the 4 to 6 screws holding the engine to bottom gear box and lift eng off. clutch is right there. It could be the teeth on the lower branze gear are stripped. lay machine on its side and with tines off remove gear box cover.
Apr 08, 2013 | Ardisam Inc Earthquake Mini Cultivator
Wont start
I would check your fuel first. Replace fresh fuel, check fuel filter if equipped, check fuel line to not be clogged. When trying to start make sure fuel is getting to carb. If after checking all the above, it still doesn't start, I would check the spark. Make sure you are getting a spark, clean and or replace spark plug. Best of luck.
Aug 07, 2012 | Ardisam Earthquake Earth Auger...
Earthquake tiller viper 43cc engine will not start
I have the same issue, I thought it was the carburetor so I cleaned it and put it back together, same issue, I put a new carburetor on it same issue, has great spark, if I spray carb cleaner into it, it will start and run for a few seconds even throttle up, but then it dies, and will not start again without carb cleaner spray, and fuel is fresh and properly mixed, very confusing indeed.
Apr 17, 2012 | Ardisam Earthquake Mini Cultivator 43cc...
Earthquake Viper 43C engines revs up and then quits
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Ardisam Inc Earthquake Mini Cultivator
Older model earthquake rear tine tiller won't start
Sep 30, 2008 | Ardisam Garden
Garden Logo
174 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
