Question about Vacuums
I need a part for my DC23 motor head. One of the ends that the brush fits into is broke. How do I order that with out the whole assembly?
LizDahl
  • 75 Answers
SOURCE: Power Head for Electrlux Oxygen Ultra
I work for Aerus Electrolux. My office # 570-326-1731 Call me and I will help you order the part. Liz
Posted on Feb 26, 2008
  • 3 Answers
SOURCE: I need a new belt drive gear.
Here's the Bosch website where you can order from the parts list . http://www.boschappliances.com/site_tools/orderparts.aspx?menu_id=34&menulevel=0304 Then click on Order Accessories and Additional Parts spacer.gif spacer.gif Looking for accessories for your Bosch range or cooktop? Or perhaps you're looking to purchase additional parts? Order here. blue_arrow_rt.gif
It will take you to another window. Type in the Model # BUC11700UC. It'll display the picture and part number. Click on the part # to order.
Posted on Jan 01, 2009
  • 430 Answers
SOURCE: Need to replace motor brushes on Kenmore canister
If you can see the arcing you are likely in the motor housing. The brushes are specific to the motor depending on RPM. Most brushes and motors in Sears units are supplied by AMTEK Lamb. The color on the plastic housing and stamped model # on motor will help identify the correct carbon brush, however new brushes will NOT always solve your problem if the motor is arcing.
If the armature is worn like an apple core or if the lines between segments on the copper commutator are gaping and not parallel you will need a new or rebuilt motor.
If brushes are properly removed there is a tiny flag terminal which will slide out of most brush housings where the wire meets the brush itself. New brushes are best installed after dressing the armature surface with a fine carbarundum seating stone or very fine wet dry sandpaper and then the motor is run in at half speed at reduced voltage.
|There is usually a hold down clamp over each brush to seat it and a lock tab underneath to align the new brush.
Posted on Oct 01, 2009
  • 294 Answers
SOURCE: The floating wheel assembly stud broke off
You should be able to purchase one from any Hoover dealer. Cost of this part is about $5 USD. The wheels and axles do not come with it, but need to be installed into the new one. Hoover.com you can lookup your nearest dealer.
Posted on Oct 11, 2009
  • 85 Answers
SOURCE: Brush assembly won't spin
you must replace the pump thats what the belt is attached to
Posted on Dec 16, 2009
How do i remove the brush bar?
Hi there, it's Jack at Dyson.
It's quick and easy to remove the brush bar from DC23's turbine head - there are two round catches to turn, and a slider catch to undo:
Once you've removed the soleplate, the two brush bar sections pull out. You can then check the Turbine head for blockages, and carefully cut away any threads or hair taking care not to damage the bristle tufts.
I hope this helps. If you'd like any further advice on using or maintaining your DC23, just give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 03, 2015 | Dyson DC23 Bagless Canister Cyclonic...
My dyson dc23 has recently started making a loud squealing noise. I have had it for about 3 years now with no problems. but it is so loud I do not even want to use it. I have checked it all over, no c
hi sophie, it's jack at dyson.
if your dc23 is making an unusual noise in use, this could be caused by something simple such as a part or seal being slightly out of position. the rotating brush bar in the turbine head floor tool is driven by the machine's own airflow, so if the brush bar won't rotate as fast as normal it sounds like something is also affecting performance.
this should be easy to resolve, and we may even be able to sort things out over the phone by talking you through some simple troubleshooting checks.
when you have your dc23 easily to hand, please give our experts a call directly on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
we'll look forward to speaking with you.
Jan 22, 2015 | Dyson Stowaway DC23 Bagless Canister...
My brush bar keeps falling down. We replaced motor but now the brushes don't spin.
Hi! If you've replaced the turbine & gear assembly and the brushes are still not spinning, a replacement brush-block assembly may be needed. The brushes counter rotate and need each other to spin. If a single brush is falling out, the brush assembly is broken. If the whole brush assembly keeps falling out, the drive pin shaft may be damaged. To order a replacement brush-block follow the link below.
Search Results
Hope this helps!
Jun 03, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
Dyson DC23 canister vacuum turbine head attachment stops spinning.
bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
May 17, 2017 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
Beater bars not turning
I'm sorry to hear you're having difficulty with your DC23. This model doesn't include a traditional user-replaceable belt - the drive system is engineered to last for the lifetime of the machine.
If your machine is a DC23 Motorhead, please take a look at the video above to clear any obstructions from the brush bar and cleaner head, and to reset the machine.
If your DC23 includes an air-driven Turbine head, please follow the steps shown in our online Support guide to make sure everything is correct with your vacuum: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/turbine-head-not-working-properly/check-the-plunger
If you'd like some further advice from our experts after you've given this a try, please contact the Dyson Helpline directly - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
If a repair or replacement part is needed, we'll be happy to confirm if this is covered under your vacuum's 5-year warranty.
Best wishes,
Jack
Dyson Online Customer Service
www.dyson.com
Nov 18, 2013 | Dyson DC23 Bagless Canister Cyclonic...
I've had my Dyson dc23 for about two years and
The brushes wear down over time as you have noticed. they are easily ordered online. Google "Dyson dc23 replacemanet parts" there are a lot of retailers for parts. Find one that is local to you, you can either pick one up from a local retailer or order one and have it delivered. I found one for $24 here is the link for you;
Dyson dc23. Don't know what the delivery charge would be for you as I don't know where you are. Ebay and Amazon should carry them also if you have premium account with either you may get them delivered for free. Good luck
Oct 12, 2017 | Vacuums
With my Dyson D23, my carpet power head attachment runs intermittently until it stops working all together.
Hi Megan, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC23. From your question, I'm not sure if you own DC23 Motorhead, which has a motor-driven brush bar, or DC23 Animal, which has a turbine-driven brush bar.
You can find online troubleshooting guides for both of these machines on our Support site. I'd encourage you to select your machine from the list, then follow the diagnostic checks shown:
http://www.dyson.co.uk/support/cylinders.aspx
If you'd like further advice from our experts after you've given this a try, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 16, 2013 | Dyson DC23 Bagless Canister Cyclonic...
Our Dyson DC23 turbine head is not spinning as well as it should. We have dismantled the brush bars and they are now clean on the inside and out. And there is plenty of suction. The head does work properly...
Call them, explain your problem and probably they will send you replacement part, at least they will describe what part is malfunctioning, and you can purchase on amazon or something, here: Amazon com Dyson DC23 parts I hope this was helpful. Have a nice day
Aug 15, 2011 | Dyson Stowaway DC23 Bagless Canister...
Now that I just fixed my Lux Legacy canister vacuum, I need help on my other Electrolux Regency Series upright! The vacuum works fine but the rotating brush does not work and the brush motor does not turn...
There are a couple rectangular holes on the bottom of the power nozzle, beside the wheels. These have tabs in them that need released with a standard screwdriver.
rogerpotts_10.jpg Once they release, turn the vacuum over and lift cover of power nozzle at the back. This pulls the front of the cover out of the lip on the "bumper".
Once this is done, you'll need to unscrew the screw at each end of the brush. Lift the brush out and thoroughly clean it, including the ends.
Check the wiring to make sure they're connected to the terminals of the motor. Also, check the belt for wear and tear. These belts can last for five years or more, but if it looks bad a good time to replace it is while you have the power head apart.
When reassembling the vacuum, ensure the belt is fitted properly around the motor shaft and brush.
Insert the front of the cover first, ensuring the edge fits neatly beneath the lip on the bumper all the way around. It takes a little manipulating to press the back into place. Make sure both tabs click into the locked position. Turn the vacuum over and reinstall screws. Try to rotate brush by hand a few times.
At this point, plug the vacuum in and turn it on. If the power head doesn't run, press the reset button. If the power head motor still doesn't run, it could be due to loose or disconnected wires that lead to the reset switch, a bad reset switch, or even a bad motor. The vacuum needs to be taken to the nearest Aerus Electrolux store for further diagnosis and repair.
http://www.aerushome.com/storelocator/
Jan 09, 2011 | Vacuums
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
