Question about Garden
Change a spark plug on earthquake vector - Garden
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
Earthquake Vector Compact Tiller Model#26750
Did you pull the spark plug and clean it, as well as the plug well and compression ring. Blow it out with canned air and dry before replacing the plug. Be certain the plug GAP is correct and it is free of carbon deposits. Rest the plug, tighten by hand and let her go. See if that fixes the problem.
Feb 27, 2014 | Earthquake Vector Compact Front Tine...
Cdi box, I keep blowing them after installing i get about 5 minutes and then lose spark to 2 of the 3 coils on my 2005 Yamaha Vector. Help
I had the same problem with my 2006 Vector. Blown 4 CDI units. Changed out complete wiring harness and Stator, new plugs, Carbs. We narrowed it down to the coils. They were for an RX1 (based on the part number). swapped out with OEM vector coils. installed new CDI.. Sled is running flawless now.
Jan 03, 2014 | Motorcycles
Earthquake cs4518 wont start
pull the spark plug out and check it for wetness. you may have flooded it unknowingly so it won't start. if it is wet, blow it off or let it air dry. turn the saw so the spark plug hole is facing down and pull the rope a few times to clear all the excess fuel out of the cylinder. put the plug back in and with NO choke try starting it again. if the plug isn't wet let me know and we will see if we can figure something else out
Feb 16, 2013 | Earthquake Chain Saw - CS4518
Wont start
I would check your fuel first. Replace fresh fuel, check fuel filter if equipped, check fuel line to not be clogged. When trying to start make sure fuel is getting to carb. If after checking all the above, it still doesn't start, I would check the spark. Make sure you are getting a spark, clean and or replace spark plug. Best of luck.
Aug 07, 2012 | Ardisam Earthquake Earth Auger...
Earthquake tiller viper 43cc engine will not start
I have the same issue, I thought it was the carburetor so I cleaned it and put it back together, same issue, I put a new carburetor on it same issue, has great spark, if I spray carb cleaner into it, it will start and run for a few seconds even throttle up, but then it dies, and will not start again without carb cleaner spray, and fuel is fresh and properly mixed, very confusing indeed.
Apr 17, 2012 | Ardisam Earthquake Mini Cultivator 43cc...
How do I change the battery?
There are two ways to charge the battery on this model spotlight. However, if you do not have the wall charger or cigarette lighter plug you will need to contact Black & Decker to see if they have replacement parts. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Aug 05, 2010 | Vector 2M Pwr Rch Spotlight
Earthquake Viper 43C engines revs up and then quits
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Ardisam Inc Earthquake Mini Cultivator
Older model earthquake rear tine tiller won't start
try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Sep 30, 2008 | Ardisam Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
