Question about Vivitar Cameras
I have a Coleman 2V9WP And have no clue as to how to operate the strap hook. all I see is a little knob that's turns back and forth and nothing happens when I turn it!
Need specific instructions on how toattach the Vivitar strap
SOURCE: Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Posted on Jan 18, 2008
IrishDruid
  • 2712 Answers
SOURCE: I need an instruction manual/operating instructions.
Download it here:
http://dl.owneriq.net/3/31de563d-8270-48af-ad07-690fa18d5199.pdf
Posted on Jun 23, 2009
  • 15 Answers
SOURCE: According to the instruction manual,
I have this model and the switch in the back turns the Frog on and off. The knob only makes the mist light or heavy.
the hello kitty and other models that don't have the seperate switch use the rotating knob to turn on and off.
Posted on Dec 22, 2009
  • 494 Answers
SOURCE: clogged regulator?
Disconnect the disposable bottle and make sure the stove's gas adapter is not clogged with insect debris or something. Also make sure your bottle is not empty by trying another one just in case! Douglas
Posted on Jul 10, 2010
wd4ity
  • 4565 Answers
SOURCE: Battery is charged, but bike will not start. When
First, check the "Run/Stop" switch on the right handlebar switch housing. Make sure it's in the "Run" position. If it is, your starter relay may not be working. The relay is exactly like those on your car, a one inch plastic cube. Now, where it's located, I'm not sure. It could be under the seat or behind either of the two side covers on your bike. Once you find it, turn the switch on, hold on to the relay, and push the start button. You should feel the relay click. If it does click but the starter does not engage, you need to test the voltage coming out of the relay.
To test the output of the relay, look at the end of your starter from the right side of your bike. You'll see a five sided plate on the end of the starter solenoid. At the top of the plate, you'll see a single wire plugged into the starter. Unplug the wire and stick a test light probe in the connector on the end of the wire. Again, turn the switch on and press the start button. If the light lights up, your relay is good. If not, the relay is probably bad.
To do a final test on the starter, remove the five sided plate by removing the three small bolts that secure it. You'll see a plunger inside the solenoid. Make sure the bike's transmission is in neutral. Using a large screwdriver, push the plunger into the starter solenoid. The starter should engage and turn the engine over regardless of whether the switch is "on" or "off". Make certain that you push the plunger all the way in. If the starter does not turn, you starter is bad.
Good Luck
Steve
Posted on Nov 24, 2010
The 2V9WP BL Megapixel Duo2 waterproof coleman camera keeps resetting the date and time back to January 2015. Can you advise on how to get this set so that it will hold the proper date and time?
I would imagine that this information is available within the manual. If you are following the steps outlined in that, but the problem persists, return it to the vendor.
Sep 13, 2016 | Coleman 2V9WP-BL 20.0 Megapixel Duo2...
Coleman 2v9wp-how do i import to laptop
Most cameras do not require being on to download pictures . in fact mine will shut the camera off if I try with it on
Sep 27, 2015 | Coleman 2V9WP-BL 20.0 Megapixel Duo2...
My coleman 5033-700 does not have a ignite button, so how do i light it?
Turn the knob to the light position, light the heater with one of those long bic lighters or a match, turn the knob back to the run position. Takes a little while for the catalytic mat to fully light up.
Jan 12, 2011 | Coleman 5033-700 Utility Heater
2003 HONDA ODYSSEY VAN WILL NOT HEAT
Your problem might be that the Heater valve(located under the hood by the back wall, circle in blue in the picture) is not opening.
-Have someone turn the temperature knob inside the van slowly back and forth from hot to cold.
-You should seen the cable(letter B) (note:cable should be connected to lever on top of valve letter C) move back and forth as the knob is being turn.
-Check to see if the screw on top of the valve(color red on picture) turn back and forth will the cable and lever.
-if the screw turn very little o not at all. Valve is bad and need to be replace.
Dec 13, 2010 | 2006 Honda Odyssey
It wont lite, how do you lite the pilot, where is it located, do you have a manual i have a coleman presidental 3 furnace
There is a window directly above the gas control valve. Either a spring held latch or a screw off cover need to be removed to access the pilot. To light the pilot, turn the knob to pilot and hold down while lighting pilot. The pilot in straight back inside the hole about 10 inches. Use a long fireplace match or rig a wire to hold the match. Once the pilot lights, hold the control knob down for about 30 secs., if it stays lit after release, turn to "On" and operate normally.
Dec 13, 2009 | Tools & Hardware - Others
Unit was used about 5 weeks ago running fine went to use the other day and no go the batterry is still full strength pump doesnt run nothing works i put a new pump in about 4 months ago
Blown fuse on circuit board. Take one side off, find the board. Fuse is water tight sealed. Remove the seal and replace fuse. This seems to be a rather common problem, but coleman doesn't give any help on it. There are only aprox 7 screws that hold the case together. One little one in under the decal on the front just blow the knob. THERE IS NO NEED TO TAKE THE KNOB OFF.
Oct 14, 2009 | Coleman Hot Water On Demand
2001 toyota camry - turns over but will not start, give it a little gas and it starts but will shut off when you take your foot off gas, and sometimes starts with no problem?
under the throttle body there is a cream colored plastic motor with two philips head screws in it,you need to remove that along with the air cleaner assembly,once you have done that try turning the little knob that is sticking out from where the motor was,it should turn back and forth with no catches, if it does catch on one or both sides it needs to be cleaned,the easiest way to do that is to purchase a can of throttle plate cleaner from a auto parts store and have someone hold the gas pedal down with the car off to open up the throttle plate and you should see a hole just beyond that that leads the inside of where that little knob is,spray some cleaner in that hole and work the knob back and forth..do this a few times and then reassemble and that should fix your problem,this is all assuming this is a 2.2 ltr 4 cylinder,hope this helps
Sep 22, 2009 | 2001 Toyota Camry
How to operate a coleman two burner stove using liquid fuel
If you are talking about the old type that runs on Coleman fuel, start by putting some oil in the hole beside the pump knob to make sure that the gasket is lubricated. Fill with fuel and pump it up, keeping your thumb over the hole in the end of the pump knob. When you have pumped up enough pressure, turn on and light the main burner, then secondary burner if necessary.
Jul 06, 2009 | Coleman Sport & Outdoor - Others
Control for fan blower not working on any speed.2005 santa fe
Don't.  What you have to do is take the ashtray out then remove the 2 screws.  Pry the whole assembly off and replace the switch in the back. The knob only moves the switch back and forth and nothing more.
Oct 15, 2008 | 2003 Hyundai Santa Fe
Cameras Logo
53 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
