Question about Skil Tools & Hardware - Others
How to Change sanding belt on skil 3375 belt sander?
    Loyalty:
    Visited the website for 30 consecutive days.
  • 473 Answers
How to Change sanding belt on skil 3375 belt sande - xdxwquxxhdb5sowm+jekekccy644pltwi4kxztabvpm4yillrjg8s1elesrf1xwwquxxhcbo3f+p4r1faurie75aaaaaelftksuqmccaa==
Posted on Apr 19, 2017
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
comax
  • 154 Answers
SOURCE: Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Posted on Apr 14, 2009
  • 302 Answers
SOURCE: how to adjust belt on skil belt sander
There should be a tracking adjustment knob on the side of the sander behind the front roller. Run the saw and adjust this knob to center the belt. You will probably have to do this every time you change belts. Hope this helps you...
Posted on Sep 12, 2009
SOURCE: what is the belt size of a skil 593 belt sander?
2 1/2" x 16"
Posted on Sep 13, 2010
Biggdex35
  • 333 Answers
SOURCE: I have a Skil 4
18 inch is the biggest I seen however I couln't find your model number. Here is a site tell you evertthing You need to know.
http://www.ereplacementparts.com/
Posted on Oct 06, 2010
I have a pressure control skil octo Sander .i think i pressed down to hard now the pressure light stays on and it won't sand but Motor runs good
The transmission between the motor and the sanding belt has been damaged by the excessive pressure you applied. Check it carefully to see if something got bent and operation can be restored. If it is gear driven and you broke off some of the gears then .....................................
Sep 16, 2015 | Skil Tools & Hardware - Others
I have a skil sand cat 2.5 x 16" belt sander model 593 no manual how do I put on and take off sanding belt?
The people at Skil will provide the data you seek Contact them on-line via this link. https://www.skiltools.com/Parts-And-Service/Pages/Email-Us.aspx
Mar 04, 2015 | Skil Tools & Hardware - Others
Skil 593 belt sander manual required
Try the Skil website for product support. There may be a manual to download or have mailed.
Oct 21, 2013 | Skil Tools & Hardware - Others
Cannot tighten then belt on a skil 594 belt sander
Have you tried the next smaller sized belt? If you tried a 24", have you tried a 21"? ... or, if you tried a 21", have you tried an 18"? ... etc.
Aug 12, 2013 | Skil Tools & Hardware - Others
I have a Skil Belt Sander 405. I bought at a sale. How old is this sander? How can I get a belt for this sander?
http://cgi.ebay.com/4-x-21-3-4-sanding-belts-36-grit-qty-10-/310329120043?pt=Sanders_Sandblasters&hash=item48410e952b
this is the type of belt it uses (size rather) 4"x21 3/4" you can find them on ebay.
http://www.skiltools.com/en/ here is the official skil website. they can probably email you an owner's manual if you wish
hope this helps out. this one is vintage from what i understand
thanks,
mike w
Jul 07, 2011 | Skil Tools & Hardware - Others
I'd like to purchase a table support (for the disc
Just the support is not available. You have to buy the complete Table. Its PN 2610959405
its about $24.00 You can get it Here
Jun 29, 2011 | Tools & Hardware - Others
How to adjust belt on skil belt sander
Sep 11, 2009 | Sander Tools & Hardware - Others
Tools & Hardware - Others Logo
217 people viewed this question
Top Skil Tools & Hardware - Others Experts
ray gallant
richie46
Are you a Skil Tool and Hardware - Other Expert? Answer questions, earn points and help others
