Question about Sewing Machines
Needle broken taken old one cannot fit new one
  • Sewing Machines Master
  • 12,302 Answers
Consult your owner's manual.
Make sure you are using the correct needle for your machine. Some machines use different kinds/sizes of needles.
Be sure the needle holder (the screw) is loosened enough to allow the new needle to be inserted and push the needle as far as it will go before tightening. BE CAREFUL not to lose that screw!!!
Verify that the flat side of the needle is facing the correct direction when installing. (Usually the flat side faces the back of the machine, but some machines differ.)
https://www.youtube.com/watch?v=bnDB2kldaKA
http://www.ehow.com/how_4597754_replace-needle-serger.html
Posted on Apr 15, 2017
My needle keeps falling out. I unscrewed the set screw, put the new needle in, then it falls out. I had just taken out an old needle by unscrewing the set screw and didn't touch anything else. Help
Be sure to unscrew the set-screw and extra turn and then insure you are pushing the needle all the way up before tightening it. Could also mean the set screw is stripped...
Dec 11, 2016 | Sewing Machines
Upperlooper needle is broken
do you need to find a place to get more needles?
Apr 21, 2016 | Sewing Machines
How do I replace the right hand needle in my Juki MO -50
Consult your owner's manual. Be sure you have removed the broken needle that is still in the machine. Make sure you have the flat side of the new needle facing the correct direction and that the needle screw is loosened enough to allow the needle to fit in the hole.
Here's a manual you can download. Page 15 is where the needle instructions are located:
http://www.manualslib.com/manual/702196/Juki-Mo-50e.html?page=8#manual
Oct 23, 2015 | Juki Sewing Machines
Skipping stitches
check tensions especially on the needle thread
check the needle to hook timing
check that the needle in fitted correctly ( slight groove to the thread and the small cut away to the bobbin hook
have it service by the approved sewing machine agent
Sep 02, 2015 | Sewing Machines
I have a highlead gc128m'd3 and my needle had broken I have taken it out and put a new 1 in but it says error 7
Make sure you put the needle in properly then unpluf the machine for a minute to clear itself out and try it.
Aug 16, 2014 | Sewing Machines
How to chang ethe needle
there should be a little hand screw near the top of the needle, loosen it enough to slide the broken needle out, replace with a new needle and tighten, Just remember, if you don't have the needle in properly you will ave issues. Usually, the flat part of the needle goes to the right, I have a brother sewing machine and the flat part on mune goes to the back though. Just take note when you remove the old needle as to the position. Also, a little known fact, a sewing machine needle should be replaced after 8 hours of use.
Jan 16, 2014 | Sewing Machines
Needle wont move singer 478
I have a Kenmore sewing machine. I'ts about 30 to 40 years old. I have never had a problem with it until today. The needle got stuck down where bobbin is. I don't know if it should be seen by a pro. I can not get the needle out. The Bar on the side will not move either way. help...........!
Jul 06, 2013 | Singer Sewing Machines
How do I change a broken needle in a Barbie sewing machine
call or email the sites below about the needle
sewvacdoctor.com
a1sewingmachines.com
Oct 10, 2012 | Barbie Sewing Machines
Change needle?
If you are asking if you should change the needle, yes. My experience is that a dull needle will cause problems long before it breaks. If you are asking how to change the needle, then: first raise and then remove the foot (not really necessary but makes it easier) If possible do not remove the screw that secures the foot. Next loosen the small screw that secures the old/broken needle in place. Remove the old/broken needle, paying close attention to the needle's alignment (which direction is the flat side of the shaft facing) Insert the new needle with the same alignment as the old needle. Tighten the small securing screw, replace the foot and tighten the screw that holds it in place. Rotate the machine by hand to insure that the new needle does not strike or rub against anything during it's full cycle. Sometimes a broken needle will indicate a timing problem or a incorrectly installed bobbin holder. Re-thread the machine and check for proper operation.
May 16, 2011 | Euro-Pro Deluxe 7100 Mechanical Sewing...
My needle broke. I replaced it. Now when I lower the needle to grab the bobbin thread it is hitting something. I have taken the bobbin case out and put it back in but it still wont work. Any suggestions? ...
It sounds to me like you have replaced the broken needle with one that is too long (wrong size).Check your manual for the proper needle size and look through your collection, or head down to the local sewing shop and pick up a new pack of proper sized needles. Now if the needle you replaced the broken one with is the same size, you most likely didn't loosen the set screw up enough and therefore didn't slide the needle up far enough before locking it in. Double check this.
Good Luck!
Chris
Feb 09, 2011 | Singer Sewing Machines
Sewing Machines Logo
87 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
