Question about Kitchen Ranges
What does Pr1 mean on a range master timer? - Kitchen Ranges
Owners Manual appears silent on two questions.
1) Question posted under Jasco GE timers.Timer is otherwise not identified as type, model or brand.Certainly this information shows on product manual.
2) Copy following link to help identify timer and download possible manual:
3) Upward operational temperature for digital timers usually ranges 120-155 F. So this should not be issue in garage until global warming eliminates all electronic gadgets, batteries, and seriously affects electric transmission lines from power plant.
4) Downward operational temperature for digital timers vary widely by type and model number of timer.Some become unreliable at freezing. Some last 1 month in freezing. Some are rated to zero F. Some rated minus 10-40 F.
5) Smart plan is analog timer instead of digital timer. type timer will operate on electric power, and not be affected by temperature fluctuations. However timing is not down-to-the-minute 7-day as with digital timers.Note appliance watt rating before buying timer.
6) Two-outlet plug-in timers are not 2-channel timers or 2 circuit.2-channel timer means that the timer can be programmed for two separate timing programs, with each timer program controlling separate load with separate schedule for each load.
7) Example 2-channel timer: Intermatic 1125 digital timer.Note operating temperature -40F to +155, making this especially hardened timer, with wide range timing applications excluding delay functions, But with 1 year limited warranty as is typical with most timers.
Dec 05, 2012 | Jasco 15079 SevenDay TwoOutlet Digital...
My 1996 Range Rover HSE ABS light went on and the brake pedal goes to the floor. Brakes were working fine prior to this. Once you pump the brakes; they work
are you losing brake fluid? you may just need to bleed the brakes if you bleed them and have the same thing happening, you are going to need a master cylinder, but first check around at all four calipers and around the brake booster and master cyl, for wetness this means theres a leak.
Aug 03, 2011 | 1996 Land Rover Range Rover
I have the H5CR-B 100 to 240 V AC digital timer. How do I change the timer from minutes to seconds?
You have a DIN panel mount SPDT (single pole double throw) timer.
This is input ON delay timer that receives input that causes timer to start a delay countdown, or signal off delay timer that receives input that causes timer to turn on for specified countdown, or a cycle timer that repeats same program pattern over and over in a set amount of time like every 5 hours and 12seconds, or an ordinary interval timer.
Apparent manuals:$FILE/D19H5CR0302.pdf
Manual says: Field-selectable time ranges from 0.001 second to 9999 hours.
My impression is that this means timer can be set for durations ranging from .001 seconds to 9999 using the 1-4 keys
Manual says: Change the timing range with the increment keys (1 to 4).
Use keys 1-4 to change data when setting timer when in the set mode.
It looks like you set seconds or milliseconds with #1 key
Manual shows contact information
Measuring and Supervisory Controls Department
Shiokoji Horikawa, Shimogyo-ku
Kyoto, 600-8530 Japan
Tel: (81)75-344-7108/Fax: (81)75-344-7189
One East Commerce Drive
Schaumburg, IL
885 Milner Avenue
60173 Scarborough, Ontario M1B 5V8
Feb 02, 2011 | Omron Hardware & Accessories
I have a GE slide in stove/oven that is showing a "F-1" code on the display. What does this mean?
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Sep 15, 2010 | General Electric Stove/Oven/Range Chrome...
After my oven heats up and ive set the timer it starts beeping and showing F3 and doesnt stop soihave to turn it off
The "F3" error code means the oven sensor is open.
An ohmmeter reading for the open circuit should be "∞".
Resistance should be measured across both wires.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
- The part number for the oven sensor is AP2023862
Here are the break down diagrams for the GE range Model JB940AB1AA
Mar 22, 2010 | General Electric Stove/Oven/Range Chrome...
Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Mar 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
F2 code on my whirlpool stove buttons not working.
The F2 could mean a timer/control has detected a stuck/shorted keypad. Depending on the model number though it could also mean a shorted oven temperature sensor.
In the event it is a stuck keypad detected, the timer or keypad will need to be replaced. You should first attempt to reset the breaker or unplug the range for a couple of minutes to see if that resolves the error code.
If it is the model that uses F2 as the shorted sensor code, you`ll need to replace the oven sensor, there`s no way around that one.
If you can provide a model number by replying to this post I could try and be more specific, as right now I can only generalize with the most common F2 error codes meaning for Whirlpool manufactured ranges/ovens.
Hope that help`s, let me know.
Good luck.
macmarkus :)
Dec 06, 2009 | Whirlpool 30" Freestanding Gas Range -...
I bought a slide in GE range. Every once in a
Its a fault code. should be in the manual that come with the range. In the troubleshooting section.
Aug 19, 2009 | Ovens
Manual needed for Range operation: Specifically timer reset
I found the work-around to be to decrement the timer to 0 as a means of canceling it, "unset it" if you will.
Dec 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
FRigidare new stove installation
Loud pop means electrical fault occured. There may be and internal fuse in the oven that blew. Probably blown oven element but certainly open circuit to timer. Remove back, check for supply to oven timer. If supply is there, the timer can be bypassed to allow for oven element to work as clock replacements are very expensive.
Nov 09, 2008 | Frigidaire FEF355 Electric Kitchen Range
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
