Question about Element Televison & Video
I have a element flx 2210 when I pressed power a blue light turn on and the element logo come out for 3 sec and goes out and keep a black screen some one told me that is the LCD board n
    Top Expert:
  • Element Master
  • 75,025 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Apr 15, 2017
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Element flx 2210 does not power up automatic after pressing the power buttin
You have classic symptoms of a failing power supply board. As others have stated this is caused by the filter capacitors on the power board. This model uses the 200-000-xxxxtltx power supply which is the same one found in the Polaroid TLS-01911c TVs. Here is a link to a repair guide that shows what to look for and replace on this board to get you TV back up and running again.
I hope this helps,
Jan 07, 2012 | Element Electronics FLX-2210 22 in. LCD...
When I have it plugged in, I get the yellow led light. Then when I push the power button the led turns blue, and the unit powers completely off, then goes back to yellow led.
it might be the problem with the internal wiring circuit ,...but not with any led lights. to get more information on led lights and led light bulbs visit ....;
Nov 29, 2011 | Element Electronics FLX-2210 22 in. LCD...
I have on element flx 2210 22inch lcd tv and when i power the tv to on the little blue light lites up for say 5 to 10 seconds then goes out and changes to amber without coming on and when looking down...
As others have stated your problem is most likely caused by bad capacitors on the power supply board. This power supply board is the 200-000-xxxxtltx and is the same board used in the Polaroid TLA-01911 TVs. Here is a repair guide that shows what capacitors to look for and replace on this board to rebuild it. This is much less than buying a new board even if you could find one for sale.
I hope this helps,
Apr 22, 2011 | Element Electronics FLX-2210 22 in. LCD...
My screeen has gone white on my tv how do i fix it on my element flx-2210 tv
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
I hope this helps you out.
Jan 30, 2011 | Element Electronics FLX-2210 22 in. LCD...
My element FLX 2210 has a problem. The tv turns on, but i cant see the picture, the sound is perfect. If you look closely at the tv you can see a faint image of the screen but not well enough to view...
This part should fix your problem.
Oct 20, 2010 | Element Electronics FLX-2210 22 in. LCD...
Black box appears on my element electronics flx-2210 television
Check your closed caption option in the menu, seems its been turned on to Text option, just turn closed caption option off.
Jun 13, 2010 | Televison & Video
I have an Ele flx2210 Tv. It turns on, the word
It sounds like the backlight inverter problem, look to see if you do have 24vdc feeding the inverter board, if you do not have this, then look at the power supply for bad caps with bulging tops.
Jan 07, 2010 | Element Electronics FLX-2210 22 in. LCD...
I get sound but no picture. The "element" logo comes on and then just a black screen with sound
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Dec 05, 2009 | Element Electronics FLX-2210 22 in. LCD...
Televison & Video Logo
29 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
