Question about Garden
Adjusting the carb on a 4stroke propane weed eater lehr
  • 109 Answers
SOURCE: Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Posted on Apr 22, 2009
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
  • 62 Answers
SOURCE: poulan ppb 250 weed eater, only runs with choke on,
Posted on Sep 25, 2009
  • 61 Answers
SOURCE: Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Posted on Apr 29, 2010
SOURCE: How to restring two-string weed eater
how to restring a poulan weed eater
Posted on Jun 07, 2010
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
New 5 hp LEHR propane outboard motor requires 4 pulls to start. Not reliable at low revs, misses and stalls.
You need to adjust the needle valve that controls the propane into the carb, Lehr website has videos about this, its real simple, you need to add more fuel than reset your idle speed, mine needed the same thing, these motors need adjustment at time of sale and many places do not do it.
Aug 20, 2013 | Lehr Propane Powered Outboard Marine...
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Which trimmer starts the easiest and is built to last the longest? I'm considering the Honda 4-cycles and the Lehr propane models among others. Thanks...
Be careful on the 4-strokes...the engines often last a long time, however, the weak point is still the carburetor, just as the two strokes were. The propane ones are a good choice, as they burn really clean, and your engine will run a long time due to the lack of contaminants in the oil. If you didn't go propane, then my suggestion would be a Stihl trimmer; there's a reason that most of the contractors and road crews use them; they will take a beating and last forever. Do yourself a favor, and search for problems for the kinds of trimmers that you're looking for on FixYa. You'll find that some brands are listed OFTEN, and some don't even have a category due to lack of need for one. If you're looking for more budget, believe it or not, MTD(troy bilt, bolens, etc) has a decent 32cc trimmer that's cheap with loads of power for its size. Hope this helped you a little. I won't give you specific models, as most of them are the same engines with small variations. I can tell you though, to stay away from the ones by Ryobi, Honda is a nightmare for repair, Homelite is a disposable machine, as well as weed eater and poulan.
Jun 21, 2010 | Garden
Engine will not start
yes, that gas treatment stuff meant for this purpose is great stuff! you can get it in any hardware store or small engine repair place,...just mix some into your gas tank, pour it into your little ryobi thing and let her sit, problems when you go to start it up months later
Jan 31, 2010 | Garden
Mar 30, 2009 | Garden
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
