Question about Kenmore Dryers
Kenmore stackable dryer is spinning but not heating
Dryer doesn't heat. Support material suggests a blown fuse. Where is the fuse and what does it look like?
    Genius:
  • 1,122 Answers
IF YOU CAN REMOVE THE BACK PANEL YOU WILL SEE A SMALL ROUND FUSE,OR IT MIGHT BE SMALL WHITE FUSE-MIKE
Posted on Jul 25, 2009
Stackable kenmore dryer wont heat
If the dryer runs, then the 240 volt supply should be okay. If the dryer doesn't run, then the L2 leg of voltage could be missing. You would need to check the voltage at the outlet using the third image below if this is the case. You should only make this live voltage check at the outlet if you are completely confident in your technical ability to safely measure it. If the outlet is bad, it will need to be repaired by an electrician.
You could have a blown thermal fuse in the dryer that will prevent it from heating. . Unplug the dryer and access this fuse by following the procedure in the first image. The thermal fuse should be on the back of the blower housing. I will likely have black and red wires attached to it. To check this fuse, pull the wires off (with the dryer still unplugged) and measure the resistance across the leads of the fuse. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance (open) then the fuse is blown and will need to be replaced.
Oct 07, 2016 | Kenmore Washing Machines
How do I replace the fuse in the dryer for stackable Kenmore model 417.98702891
This is an excellent source. Click on the link
http://www.repairclinic.com/Shop-For-Parts/a17b6d632276-x6d6f64656c/Model-Model-41798702891-Kenmore-Washer-Dryer-Combo-Parts
Jan 18, 2015 | Kenmore Washing Machines
I have a Kenmore Stackable washer & dryer Model # 417.93702200 and my dryer will come on and spin but it doesn't get any heat to dry my clothes. what could be the problem? Where can I get the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
My dryer wont heat or spin
Heat: thermal fuse attached to the exhaust duct on the back panel of the gas dryer,usually surrounded by a black resin material situated in a housing made of white plastic, if there is a lot of lint built up it will cause it to blow
Spin: belt , motor, switch
here is a website that will help:
http://www.applianceaid.com/gas_dryer.html#noheat
Oct 30, 2010 | Kenmore 73952 Gas Dryer
Dryer portion on my stackable does not heat up.
Hello there:
please try these solutions and keep me informed on how this is going for you ok
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Dryer spins but wont heat - element okay
HAVE YOU CHECKED THE MAIN FUSE FOR THE DRYER?WHITE AROUND THE SIDES AND DARK IN MIDDLE,UNSCREW THE KNOB COUNTER CLOCK WISE TO REMOVE KNOB,SHOULD BE 2 SCREWS HOLDING TIMER REMOVE THEM AND THE PANEL SIDE SCREWS,THANKS-MIKE
May 29, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
100 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
