Question about Refrigerators
I've hot a model VV3 redbull fridge all the lights work but the fridge wont cool.Motor does nothing. Do i need to replacement the motor?
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
If the start cap/relay is good along with the thermostat, then, yes, the compressor is fubar.
But before you replace the compressor you might just want to check out the price of a new one box - might very well be cheaper than cost of repair - they will soak you on the compressor part and then nail you with the labor.. Trust me.
Posted on Apr 15, 2017
SOURCE: Maytag model #M6P09S2A portable room a/c
I had the same issue pop up on me on one of these units that was only days old---the folks at maytag told me there were no known issues on these units (recalls, etc) so I figured the blinders were on and stonewall going up. So I got a multimeter, cracked the case on the unit, checked for continuity through the motor windings, and found none. Then pulled the lower squirrel cage apart enough to get the fan off motor shaft, motor out and apart, and found a blown thermal fuse in the motor. $1.69 at Radio Shack and a crimp connector or two and Ahhhhhh, cold air again. Not that hard to do folks! Enjoy.
Posted on Sep 04, 2008
  • 171 Answers
SOURCE: I have a mini fridge
Hi ejb9,
I'm Harvey the Master Plumber.
Your question is: You have a mini fridge at school, a small Haier. Your fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
May be low on freon or cloged expantion valve. You're going to need a certified tech to check and repair. Maybe it's time to look at the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
SOURCE: Magic Chief compact fridge motor gets hot but does not cool
Look In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Posted on Feb 28, 2009
farfield
  • 462 Answers
SOURCE: Fan motor stopped working, replacement went out too!
I would look for another outlet for you to plug it in before you start anything elaborate. I assume you've done this already but spin the motor/blade. If it spins and there is little or no play in the shaft or blades causing a blade to bind up the mechanical part seems ok.
Now if you have a volt meter First check the motor for voltage, Then if you have voltage, compare it to the rating on the motor. Usually a voltage within 10% is ok. Next test resistance on the wires of the motor any resistance and the winding is probably okay. If not then the motor is out again. If you have lost voltage the control board is your next part to test. No voltage out to the motor there on the board plug and the board is the problem Power there woudl mean the motor has too high a resistance and Id check the resistance on a differant known good motor before replacing it. just so you know where you started.
Posted on Mar 10, 2009
wheelshot
  • 102 Answers
SOURCE: Amana refrigerator stopped cooling.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Posted on Apr 11, 2009
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
Where is the defrost timer on a kenmore side by side model # 106.58904801
What you should be looking for its a dead fan motor. The condenser fan motor cools the refrigerant and allows the compressor to stay cool with the returning cool refrigerant. If the fan motor is working intermittently then the fridge will do the same. Usually the fan will work for a wile but when it gets hot the lubrication to the bearings becomes poor and the bearings get worn ant the shaft will fall and the rotor will lock up. Condenser fan motor is usually located on the bottom backside of the fridge. Do not run the fridge until the motor is replaced, you can create a whole lot of other problems that will need to be taken care of by a professional. Good luck
Sep 08, 2012 | Kenmore Refrigerators
Samsung RSA1NTPE not cooling in either the fridge or freezer. Seems like the compressor is not running although it is hot too the touch.
the compressor is seized and wont pump and the motor keeps trying
to work and thats why its hot,sorry to tell you but you need a new
compressor
Aug 21, 2012 | Samsung Refrigerators
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
I have a hotpoint model ctx18klatgrwh. Freezer
It most likely means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail.
In stand alone fridges the answer could be that the cooling panel at the rear is dirty and needs thoroughly dusting / cleaning / unblocking and checking that there is enough space around it to cool properly and that it is not near any heat sources such as an oven, air vent, microwave exhaust, etc.. It could also be caused by a problem that has resulted in a loss of the refrigerant gas and will need regassing by a service engineer. Also check that the thermostat is working correctly, turn it up and the fridge compressor motor should kick in, turn it down and the motor should turn off. Also make sure that the fridge is not iced up, or overloaded, so cool air cannot circulate inside it. Best call a service engineer asap.
Sep 29, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
My cda554 beko refrigerator not cooling
hello there.........is the refrigerator motor running...(not the fan)...if this is running...pull the fridge out for access.....check the smallest diameter pipe on the compressor for heat.(not the small charging stub which goes nowhere)...in normal operation this small pipe should be quite warm to hot.....if its not it is possibly due to an internal gas leak....fridge motor will run but not cool the fridge.....if the motor isnt running but the internal fridge light is on when you oen the door it is possible the thermostat (temp control) needs replacing
Regards Sir Galahad
Jun 22, 2009 | Frigidaire FRS26R4A Side by Side...
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Motor stopped running but lights & ice maker OK
this is most likely a bad condenser fan motor. pull refrig from wall remove compartment cover on rear and inspect the fan that cools the compressor. it is either jammed or seized up and needs replacing. while your at it you may want to clean the condenser coils as well they most likely have dust and lint build up on them. this motor is fairly easy to replace yourself if your mechanicaly inclined the part number should be 833697blade and can be purchased online, at a local appliance parts supply house, or thru a sears parts and servie center near you.
to keep the unit working until you get it repaired you can put a house fan blowing on the compressor area to keep it cool and this will get temps back to normal and cool down that center frame as well.
Thanks Peyton..
Feb 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
