Question about Garden
What nozzle allows the soap to come out - Garden
What tip do I use for soap in my greenworks 1700 psi?
Hi Linda, Tip to use is the following:
65? - soap (black) nozzle: Soap tip is used in conjunction with the cleaning fluid. This is the only nozzle that can be used with cleaning solutions.
Hope this helps
Kind regards
David
Oct 31, 2017 | Garden
How do i prime my troy built 2550 psi pump for the soap?
You have to use a low pressure nozzle ( usually black with very large spray opening) With the low pressure nozzle siphons your detergent in with the spray water . If you are using a high pressure nozzle the soap will not prime.
Oct 26, 2014 | Garden
The soap dispenser does not work any more
the soap will only pull when using the soap nozzle they dont pull up the soap while under higher pressure or just use no nozzle at all
Jun 08, 2012 | Briggs & Stratton Garden
I have a karcher 3000psi 2.5GPM.Is not vaccum to bring the soap in the water line. Thank. Ed
Some soap injectors have an adjustment that must be turned to allow or increase the amount of soap that enters the line. To make it work, install the blace tip on the wand (black tip has a very large hole/nozzle). With the black tip installed there will be very little pressure in the discharge hose and soap will enter. If your machine does not have an adjustable injector you dont need to do anything for it to work. If soap does not enter, stop enging and turn off water. Remove the injector fitting and check for debris. There is uaually a spring and checkball (very simple design).
Oct 10, 2011 | Karcher G3025OH Pressure Washer
Have a troy bilt 220 lb Briggs Stratton Put the clear tube into the gallon of soap, but will not draw. Also, how do I remove the nozzle to attach the low pressure nozzle to apply soap solution?
It won't draw soap unless you have the low pressure nozzle on. It can be replaced by pulling back on the slip collar then pulling out the nozzle. The new nozzle is then put in by again pulling back the slip collar and sliding the new nozzle in, making sure the collar goes all the way back and locks into place.
Jun 19, 2011 | Garden
How do I hook up and use soap on model 020228 pressure washer
There are different nozzles. One for detergent, Max, General and Delicate. The detergent one is more a less a soaker its opening is the biggest (less producing pressure), it's the one that must be used to siphon the soap out of the container none of the other tips will allow to siphon. I hope this is helpful to you please rate this answer on how helpful it was. Good Luck and have a great weekend.
Apr 01, 2010 | Briggs Stratton 020273 Elite Series...
Karcher k3.91 how do i change from just water to soap
Twist the end of the nozzle or jet pipe until you get low pressure. This will **** the soap through
Aug 16, 2009 | Karcher PSI Electric Pressure Washer
Pressure washer won't pull the from the soap dispenser
Nozzle dirty, clean out nozzle with small diameter wire. Soap dispensing only happen at nozzle low pressure setting
Jul 26, 2009 | Honda Maxus Pressure Washer MX5222
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
My power washer does not let the soap come out when you turn the soap control on
You have to use the SOAP nozzle (Black Tip)  It is a low pressure nozzle.  The venturi effect prevents the psiphon under high pressure
Apr 22, 2009 | McCulloch FHH18A Electric Pressure Washer
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
