Question about Zanussi Dryers
My zanussi tumble dryer leaks from the door even after I've emptied the reservoir and cleaned the filters on the door. Any idea what's causing this?
4 Suggested Answers
SOURCE: Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Posted on Mar 01, 2009
  • 10 Answers
SOURCE: My siemens 750 extraklasse tumble
THE FILTER YOU HAVE IN YOUR DRYER IS PROBABLY TOO FINE
TRY A NEW ONE WITH HIGHER MICRON VALUE
Posted on Oct 01, 2010
carl_brou304
SOURCE: zanussi tumble dryer stops every 3 minutes
I fixed this problem by cleaning the float in the water tray at the bottom left of the machine. You need to remove the left side panel first. At the back you will be able to see the float that senses whether the reservoir is full through a small window. It should move up and down freely. If it doesn't then you will have to remove the reservoir cover. There is a small screw to remove, then ease the two spring clips so that the reservoir cover is released. You can now remove the float. Give it a good clean and clean inside the reservoir too. Double check that the switch is functioning correctly. You can hear it click.
Posted on Apr 09, 2012
I need to clean my filter on my beko tumble dryer!
I usually just stick the shower on it to clean out all the bits of fluff that gets gathered in there, but remember to give the inside of that hatch u brought it out of with some kitchen towel before u put the condenser filter back in.
Feb 23, 2010 | Dryers
Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Feb 08, 2010 | Zanussi TC7114W Electric Dryer
Zanussi tumble dryer stops every 3 minutes reporting full tank even though the tank is completely empty. any ideas to solve this annoyance? Thanks
Nov 27, 2009 | Zanussi ZDC5355W Electric Dryer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Feb 28, 2009 | Zanussi TC7102W Electric Dryer
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 | Dryers
Bosch tumble dryer
I've sorted mine this morning. First, disconnect from the mains - VERY important! Pull out the metal condenser unit at the bottom, and behind it, there's a small hatch in the bottom to the reservoir. This can get gunked up with water, and is very difficult to clean - HOWEVER - I've found a really easy way of cleaning it. I've got a VAX carpet washer with a hose attachment, and I simply sucked all the water out using that. If you don't own a carpet cleaner maybe borrow one. I did this this morning, and my tumble-dryer's still running happily after an hour! It is possible to clean it out without vacuum, but it takes a LOT longer, and the vacuum of the cleaner pulls out gunk that is hard to access. Another place where gunk collects is behind that hatch right at the back - there's a tube up to the right. I pulled out quite a long chunk of lint. However, that wasn't the solution on it's own, I still had to clean out the reservoir as above.
Jul 03, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Not collecting water in the tank
I also have this problem and is leaking all over my floor underneath...i've only had it a day. the condenser is soppin wet and no water in the tank..i'm dead angry...anyone else have an idea how to fix this mother F*****...thanks...clair
Sep 21, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
