Question about Exercise & Fitness
My crosstrainer elliptical consule is not working. Took it apart and doesn't seem like anything is loose. Are there batteries that need to be replaced. It is a little old. Any info will help
erpaalai
  • 999 Answers
SOURCE: dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
Posted on Jun 08, 2009
  • 204 Answers
SOURCE: what do I have to take apart to get at the and
You should be able to pop it off, unless there are some screws on either side of it.
Posted on Feb 04, 2010
maxtreadmill
  • 832 Answers
SOURCE: my console is not working. Is there a simple solution?
This unit power supply that plug in the wall, If you have a multi meter. I suggest checking the outlet and work your way back to see if their is DC voltage, assuming 12V if this voltage is not present then replace power supply. If it is present then you my have loose connections inside the the unit or defective upper console or lower electronics. The simple way with out taking the side panels off is to remove the upper console and disconnect the 4 lead connector. Find the usually red and black attach your meter and see if you get 5V DC, if you have this voltage then the upper console will need replacing. If not then I would take the side panels off then check the connector leading to the lower board if I have voltage going in and not out replace lower board.
Posted on May 31, 2010
  • 48 Answers
SOURCE: I have a used ProForm 900 Elliptical. It works
hi
it uses eddy mechanism
check very carefully eddy magnet probably one of the plastic adjusters broken)
Posted on Nov 23, 2010
ercupa190
  • 12223 Answers
SOURCE: I need a User Manual for a STEX 8020EX Elliptical Crosstrainer the one with the LCD screen - ideas any one ...?
go to www.fitness.manualsonline.com or www. iconservice.com
God bless you
Posted on Jun 12, 2012
Testimonial: "thank you - pointed me in the right direction ...."
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
If I stop moving, I use to have a delay that said pedal faster. This stopped and now shuts off if I stop and I lose my stats. How do I get the delay back ?
Does the elevation work? If not, the battery is probably dead. If the elevation works fine, then it may need to be changed in the settings menu.
Apr 29, 2014 | Precor EFX 576i Experience Series...
Need a repair to crosstrainer
Sounds like the pulley (bearing) in the back is loose or broken
Apr 27, 2014 | Tunturi C80 Elliptical Cross Trainer
Display not working. hasn't been used for over a year, is it the battery
Chances are, if it has not been used in over a year, the battery would need to be replaced. You may be able to recharge, but more than likely the battery will not hold the charge long, if at all.
Repair Parts for LifeFitness CT9100 Crosstrainer Ellipticals SPORTSMITH...
Feb 14, 2014 | Life Fitness 9100 Elliptical Cross Trainer
My Elliptical display needs battery changed - where is the battery
in rear cover 4 screws 2 each side and allen key to remove battery
Sep 21, 2013 | Life Fitness 95xi Elliptical Crosstrainer
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
