Question about Speed GPS
My trucking gps will not count of the miles the time show the speed has a dark red box that shows gps in it have turned it off reset it and turned it back on
  • 803 Answers
SOURCE: why does my gps nextar show a red light and not turn on
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Oct 31, 2009
  • 8457 Answers
SOURCE: Red rash that shows through in dark scenes. Can't
Might cause magnatic field,form.Try unplug,replug the tv an hour,move it couple inches to the left or right might help.
Posted on Dec 20, 2009
  • 4 Answers
SOURCE: showed originally 226,335 miles. overnite when
Most newer trucks and suv's have a digital odometer. the miles odometer and trip odometer are combinded. By pressing the little button that patrudes from the instument cluster will show you the orignal 226,335 miles. When you press and hold the button while the T__86.6 is displayed will reset the trip odometer. Some people use the trip odometer to monitor times between oil changes and tire rotations.
Posted on Nov 16, 2010
  • 638 Answers
SOURCE: I have a Garmin etrex
You need to make sure your GPS unit and Google maps are using the same map datum.
In your user manual:
Page 44, Setup Options, Units, Position Format: I suggest setting to:
hddd.ddddd as this is the digital format and easier to read
In Google Maps, right click - Drop Latitude/Longitude marker and this should show the co-ordinates in digital degrees. Alternatively, you can hit the SEND button in GoogleMaps, and it will send the marked location to the GPS via the Garmin website. You may have to install the Garmin plug-in into your browser first, but it's well worth it.
If this solves your problem, please come back and rate our solution, thank you.
Posted on Dec 29, 2010
Testimonial: "As I found out later, I had the wrong settings on .mm.sss not hddd.ddddd so .33 in minute/secs is .55 in decimal (more or less). You are right."
  • 2296 Answers
SOURCE: my tomtom gps only shows
You have to go into Change Preferences and click on next until you see Set Units. Select this and make the appropriate changes on all units like Kilometer, Time, Degrees, etc.
Posted on Jan 05, 2011
On turning my 6200 on the gps location is showing i am in york which is 107 miles from were i actually am ?? why is this and can i fix it
Try this resetting procedure:
1) Switch the unit OFF with that switch on the button (the one that needs the pen).
2) Now hold the power button on the top with your finger, and switch that switch on the bottom back to ON while keeping your finger held down on that button.
3) Something roughly called the Aragorn Boot Loader will appear and will count down from 5.
4) Release your finger off the power button on the top before it reaches 0 or you will have to start again.
This should have performed a hard reset, and you should be asked to calibrate the touchscreen.
May 14, 2011 | Evesham GPS
Ford-Lincoln service light 1988-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the STATUS control to access the System Check mode. Press the RESET button to display OIL LIFE _% RESET FOR NEW. Press and hold the RESET button until OIL LIFE IS 100% is displayed.
When "CHANGE OIL SOON" or "OIL CHANGE REQUIRED" is displayed on the Message Center, turn the ignition on. Press and hold "OIL CHANGE RESET' or the "RESET" button until "OIL LIFE RESET TO 100%" is displayed on the Message Center.
When "SERVICE" is illuminated, on the Message Center, press the "SYSTEM CHECK" button on the right of the display. Then press the "RESET" button. The "SERVICE" symbol and mileage will start to flash. Next, press the "SYSTEM CHECK" and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
When "SERVICE DUE" is illuminated on the Message Center, press the "CHECK OUT" button located below the display. Then press the "RESET" button. The display should now read "SERVICE DONE?" Next, press the "CHECK OUT" button and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
on Dec 07, 2009 | Ford Lincoln Continental Cars & Trucks
My tomtom gps only shows speed of miles instead of kilometer. how to change that? also I want gps to tell me to turn at how many meters instead of yards. can you help with that? thanks
Jan 05, 2011 | Tomtom Go 630 GPS Receiver
Can you check or varify your speed with garmin nuvi 255w
Yes, your mph shows up on the bottom left box, your estimated arrival time on the right...and if you're on a major highway, the posted speed limit will show up all the way on the left side. Hope this helps!
Dec 03, 2010 | Garmin nuvi 255W GPS Receiver
My 1300 doesnt seem to calculate trip data such as time or average speed, miles, etc. stays on zero. does show max speed.
is it set in similation mode?? try reset by holding down finger on bottom right hand corner of screen before you power up, and go to for software update
Dec 01, 2009 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 250W Car GPS Receiver
When you have the screen showing up the route to your destination, if you touch the box down in the left hand corner showing the estimated arrival time the screen should switch to show your current speed, max speed, compass etc.........
Jun 21, 2009 | Garmin nuvi 250W GPS Receiver
It show red light.
If you wanto refill the cratridge,even after refill you'll need to reset your printer page count to 0.Download the firmware from here
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Apr 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
My trany doesnt chge gears 1990 acura ledgend atm
I just ran into the same problem. Today my mechanic showed me 2 computers, one under the rug under the glove box on the floor. Lift rug and turn key on, not to turn car on but to just turn radio on, and see if a red light flashes on this computer. It should flash once when you turn the key on. If it flsahes more than that one time, count the number of times it flashes and then light will stop flashing and start flashing again. Count it thru a few of those times to make sure you have the number of times it flashes right. If it flashes more than once, this is called a code. Having a code means there is something wrong with car, your mechanic should be able to tell you what the code means. Mine was flashing 2X, so the code was 2. My mechanic pulled the corresponding fuse for this code, and held the fuse out for 10 seconds, and then put it back in, this reset the computer to no codes. He told me to drivew it home and then shut car off and then turn key on again and see again if any code was flashing. When I got home, no code was flashing on this computer. Good news, resetting it by pulling the fuse fixed whatever that computer was doing.
Secondly, he checked another computer under my pass. seat, to do this you need to turn key on, (do not start car), and you have to view this from the BACK seat, it should flash a red light once and then no flashing. Well, mine flashed 15X, so was a code 15. He pulled the corresponding fuse, held it out for 10 sec. and put fuse back in. It then showed no flashing except for the one time it is supposed to flash when you turn key on. He told me to check it once home, I did, and the 15 flashes (code 15) is back and what this means is I need a speed control sensor. And he said it definitely does whack out the tranny. So all I need is a speed control sensor, not a transmission replacement! Try this and see if yours gives you codes and if so, have mechanic pull the correct fuses and hold them out for 10 seconds and then put back in. Then drive your car for awhile, and recheck the computer modules again for any flashing lights (codes.) You may just need a speed control sensor!!
Oct 08, 2008 | 1990 Acura Legend
Sportrak-is it dead!
left gps switched on all day and ran battery down. installed new battery and unit aquired position as normal. clock was normal and speed was nil. panic over.
answer: need to switch gps on often.
Apr 03, 2008 | GPS
Tom tom one XLS
return it for a refund!
Dec 17, 2007 | Tomtom ONE GPS Receiver
GPS Logo
Top Speed GPS Experts
Will Halftowaite
Are you a Speed GPS Expert? Answer questions, earn points and help others
