Question about Golf
I have 48 volt club car and when I push pedals out will go for short time then stop. I'll let off the petle for short time then it will go again then stop again. What cold be the problem ?
    Top Expert:
  • 12,962 Answers
Your battery(ies) are shot. Only takes one bad battery to render the other good ones useless so start checking!
Posted on Apr 15, 2017
Solenoid clicks. Why doesn't it go?
Need to know what kind of cart you have. Ezgo, Club Car?
36 volt, 48 volt ? for ezgo look at manuf. code, for club car serial number has the year. Then maybe we can figure out something.
Sep 09, 2015 | Golf
My 1994 dodge dakota blows brake light fuse, replaced sw and still blows fuse after 2-3 times I push on pedal
You'll have to disconnect the lights to track down the short. It could be one of the lamp sockets, or something in the wiring, or in the turn signal switch.
Mar 05, 2014 | 1994 Dodge Dakota Club Cab
48 volt club car 4 12 v batteries one batterie checks 20 v when I single it out when I unhook it it checks 12 v
If you have 4 off 12 volt batteries connected in series (positive to negative leaving a positive terminal and negative terminal with no wires on then that is 48 volts. To check the batteries you have to disconnect each battery and have a load test done on each battery for 12 volts and dead cells. To get 20 volts you still have 2 batteries connected together with a good battery connected to a battery with a dead cell or else you would have 24 volts.
Oct 03, 2013 | Cars & Trucks
1998 48V electric club car - just replaced 48 volt batteries and two solenoids, but still can't get it to run. can hear back up alarm, but no juice to key switch or pedal. help!
If you go to www.studmonkeyracing.com/forums/cc48v.jpg you will find a schematic for what I believe will be close to wiring of your cart. A systematic check of volts to the various components should get you going. 1st port of call, you should see 48 volts on both sides of the keyswitch when it is on. Check the fuse in line with the red wire from the solenoid to the on-board computer.
It may simply be that you have one battery terminal too loose and it just wont allow you to draw enough current to run anything but the buzzer. Does the buzzer stop when you press your foot on the gas? If so it really does point to a loose battery connection.
Jun 10, 2011 | 3d Rose Londons Times Funny Cow Cartoons -...
2005 Club Car brake lights
check the fuses of the brake light...
and also check if the bulb is working or not..
Jan 27, 2009 | Computers & Internet
Club car golf cart will only travel 3 ft. then cuts off.
See if the motor is bad. If the motor is getting really old the bearings in it may be getting to where they do not turn so easily anymore. On some electric golf carts there is a pressure switch under the seat that if you are not sitting in the cart it will stop the motor for safety reasons. If this switch goes bad then the cart does not know if you are sitting there or not. We used to test these switches by jumping the wires of the switch together to fool the cart into thinking that we were always sitting on the thing. It is a good way to test the switch but not a great way to keep it that way, that switch is there for a reason. If it is bad then get a replacement.
*NOTE: Not all carts have this switch, check with the manufacturer.
Nov 20, 2008 | Golf
Golf Logo
414 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
