Question about Speed GPS
My truck gps will not count of the mikes the time show the speed hi also has a red box with gps in it i have reset it turned it of and on can't figure it out
I have a tomtom XL 360 WHEN i PLUG IT IN TO MY CHARGER IT SHOWS A red X WHAT DO i DO?
Here is my information again here to help you, if you did not get it in other post you made. Thanks Mike.
Hello Here is some more information for you to follow to guide you step my step. Device displays a white or red cross
If your navigation device displays a cross after you switch it on, it means that the TomTom application is not installed correctly.
Note: It is normal for the navigation device to show a cross while it is connected to the computer.
The solution depends on which TomTom software is used for updating. Check which software your navigation device uses for getting updates.
Devices using MyTomTom for updates
For navigation devices that use MyTomTom, reset your device.
Devices using TomTom HOME for updates
For navigation devices that use TomTom HOME, you can solve this problem by installing the latest application on your navigation device.Here is also a link that will help you more. This will answer all your questions Mike
http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
Sep 28, 2011 | Tomtom One XL GPS Receiver
Red lights flashing back and forth
Just a small but very important question. Is the CD/DVD tray closed?
This may cause flashing lights.
This picture shows the tray (ref. Epson troubleshooting guide)
Thanks,
Lolita
Apr 17, 2008 | Epson Stylus Photo R220 InkJet Printer
Can you check or varify your speed with garmin nuvi 255w
Yes, your mph shows up on the bottom left box, your estimated arrival time on the right...and if you're on a major highway, the posted speed limit will show up all the way on the left side. Hope this helps!
Dec 03, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 250W Car GPS Receiver
When you have the screen showing up the route to your destination, if you touch the box down in the left hand corner showing the estimated arrival time the screen should switch to show your current speed, max speed, compass etc.........
Jun 21, 2009 | Garmin nuvi 250W GPS Receiver
Freezing X-Box
dependant on what kind of noise your getting ??
If it,s the fans blocked at the rear, then your problem is the console overheating, if you leave it on for about 2-3 minutes. Red Lights will show to prove this.
The answer to your problems:- RROD Kit. And some new Case Fans. Would Recommend Talismoon Fans, run cooler And Quieter.
Mike @ Compurepair.
Jun 19, 2009 | Microsoft Xbox 360 Console
Humminbird 7300211 speed unit
Hi!
Installation of the speed/temp wheel is quite easy, here's a manual:
SW Speed & Temp
The new sensor cable plugs into the square plugin in back of your Humminbird....it's the small square connector with 4 holes.
Best of luck!
Mike
Apr 30, 2009 | Humminbird 7300211 SW Speed Sensor GPS...
My trany doesnt chge gears 1990 acura ledgend atm
I just ran into the same problem. Today my mechanic showed me 2 computers, one under the rug under the glove box on the floor. Lift rug and turn key on, not to turn car on but to just turn radio on, and see if a red light flashes on this computer. It should flash once when you turn the key on. If it flsahes more than that one time, count the number of times it flashes and then light will stop flashing and start flashing again. Count it thru a few of those times to make sure you have the number of times it flashes right. If it flashes more than once, this is called a code. Having a code means there is something wrong with car, your mechanic should be able to tell you what the code means. Mine was flashing 2X, so the code was 2. My mechanic pulled the corresponding fuse for this code, and held the fuse out for 10 seconds, and then put it back in, this reset the computer to no codes. He told me to drivew it home and then shut car off and then turn key on again and see again if any code was flashing. When I got home, no code was flashing on this computer. Good news, resetting it by pulling the fuse fixed whatever that computer was doing.
Secondly, he checked another computer under my pass. seat, to do this you need to turn key on, (do not start car), and you have to view this from the BACK seat, it should flash a red light once and then no flashing. Well, mine flashed 15X, so was a code 15. He pulled the corresponding fuse, held it out for 10 sec. and put fuse back in. It then showed no flashing except for the one time it is supposed to flash when you turn key on. He told me to check it once home, I did, and the 15 flashes (code 15) is back and what this means is I need a speed control sensor. And he said it definitely does whack out the tranny. So all I need is a speed control sensor, not a transmission replacement! Try this and see if yours gives you codes and if so, have mechanic pull the correct fuses and hold them out for 10 seconds and then put back in. Then drive your car for awhile, and recheck the computer modules again for any flashing lights (codes.) You may just need a speed control sensor!!
Oct 08, 2008 | 1990 Acura Legend
Sportrak-is it dead!
left gps switched on all day and ran battery down. installed new battery and unit aquired position as normal. clock was normal and speed was nil. panic over.
answer: need to switch gps on often.
Apr 03, 2008 | GPS
Garmin Edge 305/GSC10 Cadence and speed sensor
Had the same problem. Here is how I fixed it.
1. Changed the battery in the cadence sensor. (GSC10)
2. Turned on my garmin 305 edge outside to acquire satellites (probably not nec but did it anyway)
3. Pressed reset on the GSC10, saw red/green flash (what order?)
4. Here's the missing step: On the Edge unit, go to SYSTEM.
5. Scroll to bottom, choose ACCESSORIES.
6. On acc. page, go to bottom, under Cadence Sensor, to the option RESTART SCAN. Press That. Now your cadence and speed should work.
Feb 23, 2008 | Garmin Edge 305 GPS Receiver
GPS Logo
35 people viewed this question
Top Speed GPS Experts
Will Halftowaite
Are you a Speed GPS Expert? Answer questions, earn points and help others
