Have purchased cable before but cant remember size
How to connect miracle grow 3 in 1 sprayer to hose
you need to either purchase or find (if you have one) a female connector i think, if i remember correctly. my hoselock connector worked ok and plug it in like you would any other hose compatible tool
Jun 12, 2014 | Computers & Internet
Lost password
Hard drive passwords are difficult to remove.
These WEB sites maybe able to help you.
HARD DRIVE PASSWORD UNLOCKING - Purchase A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
Nov 01, 2012 | Acomdata Computers & Internet
Philips plasma hdtv will not come on. Replugged power, indicator light on lower right is green then flashes red (7x, then repeats). Set has been good (until now), service to set is via cable.
problem you have with this unit is 2 can Caps on a regulator board located on the main board and if you face the screen down also there are 2 caps on the board to the rights side of the screen i dont remember the values. it's cheaper to purchase the main board than to change the regulator board, also remember to check the board on the right side as it is the main cause why the tv give you that problem, just look at the capacitors you will see them looking like over sized
Jan 17, 2010 | Televison & Video
Cant upload all photos from my camera They are all the same size & format. The camera has not been dropped or anything. This problem stsrted a few weeks ago.
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
The card that you currently have might be faulty.
Format the card, note this will erase all pictures currently stored on the card.
Please also try another card.
Jan 02, 2010 | Kodak EasyShare One Digital Camera
No flip top light for Motorola flip top phone Model V276
Most likely a flex cable. The flex cable runs through the hinge. It is a high fail item. I used to replace 20 a week. Check to see if you can find a flex cable online. You will also need a small torx driver. I cant remember the size.
Jul 20, 2009 | Motorola Mobility V276 Cellular Phone
I cant adjust my picture size to normal on my Sony Wega 51" TV
the screen size feature is gray out because there is a previous option selected already and computer assumes you want always that size.So going into the menu and try to look for a previous selection related with: "screen size default". The menu allows you to selec this option and (i like to "standard" and i adjust screen size with my cable box feature who allows change size also if is needed, but now days cable box change it itself because is automatic) is install in the original program by manufacture because helps you to keep one size and you don't have to change it any moment. This default option is outside the regular screen size option, if i remember right is in set up screen. try to find this options in your user's manual to follow the right screen procedure..
Apr 21, 2009 | Sony KP-51WS520 51" Rear Projection...
Cable antena ready input repair
Purchase replacement at radio shack, disassemble the tuner, and solder the replacement in. It is not a screw in.
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
New sorround system
The cable box had red and white audio output jacks - run a red/white cable (or red and white portion of a red, white, and yellow cable) to the audio in/tv port of the magnavox
Feb 19, 2008 | Audio Players & Recorders
Open Questions:
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
