Question about Building Materials
The keypad is not working right.It will not shut off. It is running now, but have to unplug it to shut off. The on and off Lights are not coming on or off.The unit will not shut off.
Frigidaire LEQ1442ES1 will run only a few minutes. Heats up runs aprox 3-4 minutes then shuts off, starts beeping and lights on the right side of the panel blink rapidly. Pushing cancel stops it and y
Good Morning friend, thank you for your post!
From my understanding your Frigidaire dryer, LEQ1442ES1, will run and then shut down after three or four minutes. I would recommend a reset on your dryer which you can do by unplugging your power cord for roughly ten minutes.
If that does not correct the issue it sounds like a potential problem with your control panel or a sensor. I would suggest having a professional come out and repair your appliance to avoid any unnecessary part purchases. -Matt
Oct 10, 2014 | Frigidaire Dryers
The interior lights keep coming on when the car is shut off, also noticed that the keypad on the drivers door also lights up when the lights come on
I am having the same type problem with my Grand Marquis...did you find a "Solution" to your interior lights keep coming .
Jul 16, 2010 | 2000 Mercury Grand Marquis
How do i turn keypad lights on?
go into settings and look at your power settings, if you have it set to maximum efficiency backlight will shut off quickly and key lights will never turn on. this is all an effort to maximize battery life.
Dec 28, 2009 | Motorola Mobility RAZR V3
Both lights no longer work. I hear a click, but the lights do not come on.
If the bulbs are good unplug the opener and then remove the bulbs. Using a small screwdriver pull out on the center contact in the socket.
Dec 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Turntable and cooking power not working, everything else does.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The projector would not shut down...it was not
if the lamp shuts off and the projector still runs, it's a cool down mode, and will shut off when it reaches a low enough temp. if the lamp doesn't shut off and none of the keys work, the keypad may be faulty. or locked. some projectors have a keypad lock feature that makes it so only the remote can be used. check your manual for keypad lock/unlock.
Aug 09, 2009 | ViewSonic PJ556D DLP Projector
Left signal lights wont shut off all back running lights off
sounds like a turn signal switch on the column
Apr 04, 2009 | 1997 Eagle Talon
Won't power up
Device is bad or needs reset, remove the battery while the device is on and count to 30 then re-apply battery and power on!
Sep 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
After swith on only drain pump is running. All lights are on. Will not respond to fault tracing program.
Try unplugging overnight. If it won't even fill or respond to any command it is probably a bad board or keypad. I have had this happen to me and after unplugging it seems ok for a few months. I have come home and found only the drain pump running before. This was hours after I started the washer.
Jul 03, 2008 | Asko Washing Machines
Building Materials Logo
175 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
