Question about Lands Phones
Gecko error codes hot tub
I have a gecko k400 controller which codes up with P1 have it set for 2 hours times with 4 times a day
SOURCE: Hot tub won't stay at set temperature
I have a 2002 Infinity 6 man spa that I just got from a friend. I am also an Electrician. I had to replace the Spa pack because it wasn't working. Once I replaced the Spa Pack and used the tub it got up to temp no problem but once I got in the temperature slowly dropped and it couldn't keep up. After some research and discussion with a pool tech I found out that there is a jumper on some spa packs. It is a LC (low current) / HC (high current) jumper. It limits the current (amperage) that your tub draws. If you are running it on the LC setting it keeps the tub at low current by not running the heater when the jets are on. (this way it keeps the current low by running one only at a time) If you set it for HC it will allow high current to be drawn and let the heater and the jets be on at the same time. On my spa pack it is P26 Jumper. I have found it is also listed as Jumper 4 on some spa packs. the jumpers are located in the lower right of the circuit board. Make sure you shut off the power to the tub and know what you're doing before you attempt changes. you can also google "Gecko Spa Pack Service Manual" and you will find the manual for your tubs spa pack. Good luck.
Posted on Dec 18, 2008
SOURCE: driver download 4 multimedia & video controler 4 amd k400-m2
try google search
Posted on Jan 23, 2009
  • 6 Answers
SOURCE: P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Posted on Sep 12, 2009
Testimonial: "You were right! can you help mr with a P2 error code?"
mrhotandcold
  • 248 Answers
SOURCE: Need an owners manual or a relay wiring diagram
should be able to pick up one online
Posted on Oct 03, 2009
SOURCE: I get a P1 error code
Water inlet temperature to the heater is the same as preset on the controller.
I had this happen to me becouse I have a solar tank with temp of
135 farenheit.
Once I bypassed the sollar tank..no problem
Posted on Nov 09, 2009
Washer comes up with f-05 code what does this mean?
Could the unit possibly be a whirlpool duet or kenmore elite model? They are 99.9% the same. If so, it is a temperature sensor error. If you have the unit set for warm or hot water, and not enough hot water makes it into the tub by the time it is full, the washer realizes this and drains the water, to refill with warm or hot water. If the tap water never gets warm, the unit will fault out and act strange.
If the water in the tub is in fact warm or hot like it should be, the water temp sensor should convey this information to the control board. If the sensor has failed, the control board never sees this change, and sets the same error code.
If you cannot or are not willing to dig deep into this machine, call a service tech out. Chances are, the tech can have your washer running again in an hour or two. Please mark me down as helpful.
Jan 05, 2015 | Washing Machines
What does the E6 error mean
Hi Cheyenne,
Most of the time an E6 error code refers to a restriction of water in your power pack. When you don't have enough water flow the power pack shuts itself down so it does not over heat.
Possible reasons are dirty filters, air locks, restrictions of water flow,
Solutions are to make sure your water flow is as best as possible, clean your filters often, remove debris from your hot tub, and remove air locks from your power pack.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
Dec 18, 2014 | Jilong Inflatable Hot Tubs: Prompt Set...
How do you set the timer on a 1996 hot tub? It has an old timer with things (prongs) that you have to push/pull?!
These types of timers were used and are still used for many different devices. The dial represents the clock and you pull or push for the hours you want the device to run during the 24 hour clock. For a hot tub you will want circulation for at least 4 - 6 hours a day. To circulate but also to maintain the heat. With a good hot tub cover and good insulation inside the tub your circulating time would be less and save you some money. Hope that helps. 6f0fd63b-b068-4b09-9479-fc1b67bc8e93.jpg 29c9802b-b80d-438e-9f6a-66c31c024fd8.jpg
Apr 04, 2014 | Washing Machines
PTG-53XN error code p1. And hot water turns off.
Before calling service technician, open following link for Rheem troubleshoot resources including Rheem chat:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start point for troubleshooting, and can sometimes mislead.
Error P1 is 'not enough water to operate the unit:'
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
This problem can be caused by plumbing problems such as crossover, or clogged water lines, or dirty water filter, or clogged water softener, or temperature of unit set too high. Or combination of these problems.
Remember if temperature is set very high, then more cold water is used at the faucet. This means less hot water is drawn through the tankless water heater, so the flow rate may drop below activation threshold.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
Jul 08, 2011 | Rheem Tankless Hot Water Heater...
Why get a P1 error code on my Rheem tankless RTG-64xp?
1) I cannot find Rheem error code P1
http://www.palomatankless.com/owners/homeowner+trouble.lasso
http://www.palomastore.com/paloma_error_codes.html
2) BOSCH does not show P1 either:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
3) Best I could find is that folks with P1 error code report tankless fires for short period, and then turns off.
This implies air, fuel or vent problem, and can be internal, external or combination.
4) P1 appears frequently on control board descriptors, which might imply the error is control board malfunction.
5) Call Rheem 1-800-432-8373, and then add a comment to this thread and let folks know what you discover.
6) I will also call Rheem when time permits, and post what I discover.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Rheem Water Heaters
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Have hot tub with Spabuilders heating unit not functioning and getting two messages (1) FF 04 & (2) Fd 02
FF 04 and FD 02 might not be error codes.
In the UK, 'FD' stands for either 'Filtration Duration' or 'Filtration Delay'. As I'm not in the office right now I don't have a manual at hand.
Why isn't the hot tub functioning correctly??
Common Spa Builders (Gecko) error messages are, OHH, FLO, FLC, Sn1 and Sn2. Also they have three flashing dots which can appear on the display.
Kind Regards,
Ian Kime, from: http://hottub.synthasite.com
May 26, 2010 | Pool & Spa
We bought a house with a hot tub and do not have the instructions to it. We have a Manatee Electric spa heater made by Tropic Air Products, Inc manuf. 4/1997 model E-11 11 KW AMPS. We would love some...
I just looked at the exploded drawing for the Manatee. It looks like a very simple heater. The heater will simply come on whenever the pump is running and the thermostat says that the tub is not hot enough. So, for the heater, set it and forget it.
The adjustment you can make is by setting the low-speed pump timer. There should be a timer on the control box, somewhere. Generally, you set the timer to come on for a couple of hours, twice a day. During those times, the pump will come on low-speed and the heater will come on as needed.
Keep in mind that the tub will only heat when the pump is running so you will want to set the timer so that the tub has been running for at least an hour when you will be ready to use it.
Most controls will also allow you to put the pump on thermostat control, usually with a switch (timer/ t-stat). By running on t-stat control, the low-speed pump and heater will turn on whenever the temperature drops a couple of degrees.
Timer control is usually more efficient for two reasons:
1. The tub doesn't heat water when you don't need it (like while you are sleeping or at work).
2. The pump isn't cycling on and off all day and night. Cycling is not very efficient.
Tip: If you want to soak when the tub isn't hot, just turn the pump on for 10 minutes or so before you get in. That is a pretty big heater, and unless you have very poor insulation or a worn-out cover, the temp shouldn't drop too fast.
Another tip: The best way to save money on a tub is to maintain your pH. Check it EVERY WEEK! Incorrect pH will shorten the life of your heater and seals. One service call would have paid for a lot of electricity.
Please feel free to post follow-up questions.
Dec 16, 2009 | Kitchen Appliances - Others
Nov 11, 2008 | Sport & Outdoor - Others
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
