Question about Miscellaneous
My battery back up keeps turning it's self off
I replaced the battery about 2 months ago, it keeps shutting it self off every few days
  • 152 Answers
Sounds like a battery that has developed memory from not getting charged all the way may be the charger it may need replaced and if so you will probley have to replace the battery pack also hope this helps
Posted on Sep 11, 2017
SOURCE: closing itself down DEW
camcorder when turned on flashes in red DEW and closes it self down. i have taken all the batteries out and replaced sometimes after a few days the camcorder will work then DEW will rea ppear and shut itself down
Posted on Jan 05, 2008
  • 40 Answers
SOURCE: Toshiba dlp 42in. keeps shutting off . replaced lamp 5 months ago
it sounds like your lamp could be failing. check your lamp it should be clear with no frost.. here is your lamp part number 72620067
Posted on Mar 15, 2009
SOURCE: 2001 Xterra - Replaced fuel pump twice and is still not running.
I am no expert, but I just had a similar problem. The car would shake and buck when accelerating. It finally just died and would not start. After sitting for some time, the car would start and run a while, then do the same thing. I thought fuel pump. The dealer diagnosed distributor. After replacing, the car is running perfect. Something to think about. Good luck.
Posted on Mar 28, 2009
  • 65 Answers
SOURCE: my nissan max keeps shutting off while driving
It might be the immobilizer in the starter causing it to shut off. You should to go back to where you got the starter installed and see if they can do anything.
Posted on Apr 03, 2009
  • 1114 Answers
SOURCE: Yamaha RX V2400 keeps shutting off
When it shuts off, does it display anything on the front like "ck speakers" you could have a shorted wire or bad speaker. Sounds more likely than a bad receiver. Yamaha is pretty bulletproof in "self preservation" circuitry! about the only thing that takes them out is lightning and major power surges. I have been selling and installing Yamaha receivers since 1995 and have only ever seen one with a problem that was unrelated to power. and I've done hundreds. If your not using HDMI, and the Video portion of the receiver, I would definately keep the unit $ 1500.00 is no cheap receiver. Try disconnecting the speakers, then turn on the unit with a source connected like cable/sat/fios on then crank the vol and let it set, if it cuts out, yes you've got a problem internally, however, I would stronly suggest metering all of the speakers and wires for shorts. There is an internal fuse as well right near the power cord, you have to pop the top to get to it, If you have a multimeter check the fuse with resistance tone. If you get tone, you have a good fuse if not If you need to replace it. They can be found at Radio Shack etc. If the fuse is OK, chances are you've got bad transistor(s) and needs to go to service. Repair should be under 200, well worth it. If you have further questions, post a comment and I will get back to you ASAP. Hope this helps
Posted on Jun 06, 2009
1998 aurora wont start
Most commonly it's a spark- or fuel- related problem, but very often it could be something simple like a dead battery. Go to the repair shop to check it.
Nov 24, 2012 | 1998 Oldsmobile Aurora
Sony DCR-SR290 camcoder- turns off abruptly
ribbon cable located in the rotating lcd is cut. thats why the shut down its grounding it self out. needs to be replaced. real pain though, cable is serpintined around the part that rotates. sony does flat rate for prob. about 250 US
Jun 01, 2009 | Sony Handycam DCR-SR40 Camcorder
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
My 2000 chevy blazer cuts off while you are driving.
This can cause your problem if the cat is plugged and cant exhaust it will shut the motor down
Mar 24, 2009 | 2000 Chevrolet Blazer
1991 GMC sonoma ignition turns on but wont crank
check your battery first,  Then measure voltage to the starter solenoid.  No voltage at solenoid the problem is at the key switch.
Mar 08, 2009 | 1991 GMC Sonoma
System shuts off and turns to red light standby
Hello. You may want to double check your connections and cables. The only time I've ever heard a clicking before a system shut it's self down was when a kid had stuck the battery cover from a TV remote into the disc drive.
Also, if the PS3 keeps acting like that, Sony will repair/replace the unit for free including shipping since it's under a year old. Thanks and good luck!
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Closing itself down DEW
Nov 02, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Miscellaneous Logo
15 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
