Question about Lands Phones
Speed dials is not working what may be the problem
Speed dial does not work
Look at the number that is in there for the person you are trying to speed dial,your voice mail is always #1.To use speed dial you just use the number the person you are trying to speed dial lets say they are in your phone as #2,hold down the # 2 on your keypad for around 3 seconds and it should start dialing.
Jan 01, 2013 | Net10 Motorola W409G Prepaid Camera Phone
KX-Ta824 Speed dialing problem
Panisonictel.com has a FAQ for this model here
In that FAQ, there is this explanation of your problem:
When I tried to access speed dial, it does not call out.
When storing speed dial number of external parties, the stored speed dial number must include CO (outside line) access code (9 or 81…etc) even with direct line access. If the external number is 1234567, you must store the speed dial number as 91234567.
This rule applies to all system speed dial, station speed dial and speed dial key.
It looks like you're just going to have to add a leading 9 to all the speed dial numbers for that function to work.
Nov 04, 2007 | Panasonic KX-TA824PK Phone
Speed dial
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows:
1. Copy all address book entries from Sim to Phone Memory.
2. Delete all Sim Address book entries.
3. Switch Address book source to Sim.
3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial.
4. Switch Address book source back to Phone Memory.
From now on all numbers on the Sim will be in Speed Dial and you will view the address book from phone memory. Of course any number can be in both places.
Now to speed dial just enter 1#, 2# etc for any number in the Sim Address book. You will get to view and confirm the entry and then dial. In a way this is even better then the speed dial functions on older Samsungs, as the preview before dialing ensures you have the right speed dial entry.
I think it works fine. dk
Jun 20, 2009 | Samsung S8300 Ultra Touch platinium-red...
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 | Nokia 1100
Nokia 1100 speed dial problem
hi,
1.Take your phone 2.Click menu 3.Go to contacts by scrolling down 4.Go to speed dial
There we can assign the number as speed dial.
MOTO W755 Speed Dial does not work
SOLUTION: Menu to Setting/Tools to Call Settings to One-Touch Dial: Turn it ON.
Mar 31, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Speed-dial has quit working
Went into "Contacts" and selected one with speed-dial to edit. Made no changes but saved the contact. Magically, speed-dial began working correctly for all numbers. Rebooting or removing/reinserting the battery may also have worked but were not tried.
Nov 25, 2008 | T-Mobile Dash Smartphone
Speed dial not working
Maybe because the speed dial service is not on.
Click.
Menu -> Settings -> Cal Settings -> Speed Dial -> On.
then try.
Nov 14, 2007 | Nokia 6030 Cellular Phone
Speed Dial quit working
why for restart my V3 mobail?
Sep 07, 2007 | Motorola Mobility RAZR V3
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Lands Phones Logo
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
