Question about Building Materials
Have three garage doors the middle one will not work on how to hardwire or remote everything else works .
  • Brad Brown Apr 15, 2017
    Hi Richard danielsen, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 319 Answers
SOURCE: remotes don't work (3)
Did you inadvertantly hit the "vacation lock" button on the Mounted push button? This will cause the remotes not to work. Try hitting the button again, and then see if the blinking goes to solid green.
Good Luck
Posted on Jan 01, 2008
  • 121 Answers
SOURCE: Garage Door Key Pad
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
Posted on Apr 21, 2008
  • 1342 Answers
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
SOURCE: I have a Sears Craftsman HBW0777 Garage Door
I had the same issue yesterday with my remotes which are model 850CB. I fixed it by following these steps on Chamberlain's help site:
1. Press & release the "learn" button on the motor unit. 2. Within 30 seconds, press and hold the button on the remote. 3. Release the remote button when the light bulb on the motor blinks. It has learned the code. and enter your remote model number for re-programming instructions.
That worked for me. Not sure why it "lost" the code in the first place. By the way, I only had to do this for one remote, the other started working after the first was re-learned.
Posted on Dec 02, 2010
I have an older Craftsman GDO setup. 2-3 button remotes,a manual hardwired push button operator and my wifes' car has been successfully liked to operate the opener as well. Up untill just a couple of days...
I suggest you look for a Chamberlain dealer in the yellow pages and explain what you have. You are looking for a 'universal receiver' that will work with what you have.
Mar 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
I bought a house with an old (1980's) Sears garage door opener. I have two Stanley remotes that were in the house at the time of purchase. The opener works fine at the hardwired button in the garage but I...
On the remotes put switch #1 in either position and match up switches 2 through 10 to the dipswitches on the motor unit. There is a good possibility your receiver has quit working.
Mar 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener has stopped working. No
There isn't a reset but make sure the trolley isn't jammed against the bolt just in front of the motor unit.
Mar 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote capability out on garage opener
If you are having a problem with all your units that transmit a radio signal it is your receiver that is going bad. It is part of the logic board.
Jan 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hardwired code opener no longer works
Here are the directions to program your hardwired keypad.
First unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Inside light on garage door opener blinks twice when remote contr
YOu will need to explain the problem for an accurate answer. Thanks BB
Mar 12, 2009 | liftmaster Chamberlain Garage Door Opener...
All remotes stopped working on genie opener, hardwired wall switch works fine.
Your lock on the opener is probably engauged. On the wall control there is a button labeled lock. Press and hold this button for three seconds. Your remotes should work now. If they still do not work, you need to reprogram the remotes. Press the learn button on the back of the motor and then press and hold the remote button. The light will blink once. Repeat this step on the other remotes.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lack of range on Garage door remote
There is a short wire hanging down from the back of the opening motor -- pull this down as far as you can and bend it so it is pointing toward the garage door. This wire acts like an antenae.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
133 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
