Records audio not responding
I record from line input. When finished, "loading" gets to 99%, then stops.
  • 19 Answers
SOURCE: Input Echo - audio feedback loop
do you record from
a) mic
or
b) line input ?
if a)
turn off your speakers, and use headphones.
or at least turn down the volume, and change the mics position (as far away from speakers as possible)
if b)
dont route the allready recorded channels to your master while recording (-> or mute them)
Posted on Mar 31, 2008
SOURCE: Sound is not recorded
Make sure that the your audio wiring is correct. The L&R audio cables from your VCR, etc should be connected to the red and white RCA jacks on the capture card cable. The small 3.5 mm phone jack from the capture card cable must then be plugged into your PC's line-in jack - usually blue. Then in the PVR application, select line-in as your source. This is necessary because the capture card only processes video. The audio signal is passed through to your PC.
Posted on Apr 24, 2008
SOURCE: ?Error? Cannot render audio capture stream
Download intervideo windvr and your problems are over!
Posted on Sep 08, 2008
SOURCE: Can not record audio anymore
Does it create a track but there is nothing in it? Turn off your anti-virus software when you record, thats how I got mine to work. Kaspersky anti-virus was making it trip offline.
Posted on Apr 29, 2009
SOURCE: recording playback has lines through it.
What is the video head and how easy is it to change?
Posted on Jul 15, 2010
Mic not working!
Go to logitech's website and look for the latest driver for your microphone:
http://www.logitech.com/en-us/support-downloads
Install it, plug in mic, load audacity/garageband, or any windows recording application, and ensure the mic input on the application is set to the plugged in logitech/labtec mic. Ensure the input volume is set to a level that responds when speaking into mic. Press record to see if it picks up the audio.
Apr 13, 2012 | Audio Players & Recorders
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
With adobe audition 1.5 how do i get my voice to play back through edit view? Ive really been up all night trying to figure this problem out someone please explain step y step
First, be sure you see the audio track on "edit view". It shows the peak of the recording level. If it is a straight line, you have not recorded your voice. If the recording is there, you have to be sure your computer audio is set to play back through the speakers. If the recording is not there you have to set the computer to record from your input, either line or mic input. Set the level to the max. When you record you can see the input level on the two bars at the bottom of the screen. Double click on them to see the input level before you start recording. You want the level to be near "zero", at the far right. If the level is above "0" the peak indicators will turn red. You don't want red lights. Set the input level just below the red peak. Click on the red record button at the panel on the lower left of the screen. When you click the record button you may see a pop up that want you to set the recording parameters of the file. You have to make these selections before you can record. Once that is done, the record button will show the record position and audio track scroll across the screen. You will also see the level bars respond to the input. When finished recording click the stop button. You should then be able to play back the recording.
There are many adjustment and changes you can make to recorded files. The Adobe help files are very good explaining the features of the software. It is a very powerful audio system. Good luck and have fun with voice and music tracks.
Thanks for using FixYa.
Gaker
Jun 15, 2011 | Computers & Internet
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
I am a member of a paranormal group. Can I use my magnavox MWR10D6 DVD recorder to record from a cam. Is this possible?
As long as your DVD recorder has line inputs yes you can.
If your DVD recorder has a DV input, you can use a firewire cable. If your DVD recorder has audio and video inputs you can hook the output of your camera to the line inputs of your recorder and record in realtime
Most DVD recorders do have inputs, you can use either the Y/C (black round connector) or the composite (yellow connector) along with the audio inputs (red & white) RCA plugs depending on the type of camera you are using.
Sep 24, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Capturing video & audio through s-video input .
Hi, try this, go to control panel-click sound and audio devices and ensure that your system is configured to the right devices for recording from your camera. The easiest way to run any of this equipment is to set all systems at default. and purchase a USB sound/video adaptor [cheap from china] and plug your camera into this when you wish to record from it. when finished, remove the adaptor the same as you would with any USB hot swap device, your computer will revert to the default settings. Next time you use your camera , plug it in and windows will auto detect it again. Goodluck. mistyman
Aug 05, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
