Question about Hardware & Accessories
Instructions to program timer ISA304
I don't know how to program the timer
Timer programming help
Maybe the sprinkler head is not advancing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 22, 2013 | Orbit Hardware & Accessories
We inherited a Stanley weekly indoor digital timer model 51206 without instructions. Do you know how to program it? Specifically, we want to change the timer. thank you.
I know most timers and have extensive files and manuals available and know how to program most timers.
51206 timer is not identified.
Look at options below and add a comment:
1) Open following link to identify timer, and download same-similar manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
2) Add a comment and clearly describe details of timer for possible identification and instructions.
3) Add a comment with link to photo of your timer posted on Flickr for possible identification.
Sep 17, 2011 | Stanley 31200 TimerMax Indoor Weekly...
Can i put two valves on one station
You should be able to put two valves on one station. If it is too much for the timer either a fuse or a "virtual fuse" on the circuit will fail. Just turn the unit OFF, separate the two valves and turn unit back ON to reset "virtual fuse".
I am an irrigation contractor and we have many timers with doubled zones.
Gary
Sep 17, 2011 | Rain Bird 4 Station Single Program...
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I still can't program my timer
I don't have a repair for defective timer.
Question posted under Woods 59377; Utilitec 155671, Westek TE06 7-day digital timer.
Open following link for written instructions
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
This is an incandescent timer, and is not rated for TV, CFL, motors etc.
If instructions are confusing, add a comment about specific part of instructions.
If timer has problems, then test outlet with circuit analyzer
If timer is defective, then buy another identical timer at Lowes or Target, and return defective timer in new package.
If you have different timer, then add a comment and describe the timer for possible help.
Aug 23, 2011 | Woods Industries 59377 Indoor Digital...
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
I have a raindrip 2 zone water timer...I don't know how to set it. There is no clock set, so I don't know how to program it to turn on at a certain time...
You can download your instructions here:
R673CT Digital Water Timer Installation Manual
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Raindrip R673CT Digital Water Timer
Rain Bird sprinkler timer blowing fuses
Disconnect all zone wires and see if timer blows fuses. If not, one of the zone valves is drawing too much amperage.
Oct 02, 2010 | Rain Bird 4 Station Single Program...
Hardware & Accessories Logo
46 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
