Question about Hardware & Accessories
Program timer ISA304 - Hardware & Accessories
How do i remove an evebt
Usually timer programs can be edited by entering the program mode and scrolling through choices....
Some timers do not allow you to remove a program... and you have to reset timer and reprogram to completely remove program
ST01 timer has step-by-step for deleting program on page 2 of manual ... on right side of page... under changing program times... deleting ON-OFF setting
http://waterheatertimer.org/pdf/Intermatic-st01c.pdf
http://waterheatertimer.org/ST01C-program.html
Gene
Water Heater Timers Save Money
Jun 02, 2014 | Intermatic & Self-Adjusting Wall Switch...
Can i put two valves on one station
You should be able to put two valves on one station. If it is too much for the timer either a fuse or a "virtual fuse" on the circuit will fail. Just turn the unit OFF, separate the two valves and turn unit back ON to reset "virtual fuse".
I am an irrigation contractor and we have many timers with doubled zones.
Gary
Sep 17, 2011 | Rain Bird 4 Station Single Program...
It does not turn off why
Unknown if this is new ST01C timer, or older timer that worked before and stopped working.
Add a comment with more information if needed.
Timer can be defective. Battery can be low. Wiring is wrong. Timer programming has overlaps and conflicts. Program 1 is set but program 2 is not set. No programming is set. Short circuit on lights.
I suggest change battery and reset timer, then reprogram timer.
Write out schedule beforehand to avoid conflicts and overlaps.
Program 1 is ON and program 2 is OFF. Program 3 is ON and program 4 is OFF. etc.
Open following link for re-set and programming illustrations, plus battery replacement and wiring diagrams:
Sep 10, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Do not know how to set timer DT300 for Lights
Hi
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Thanks.
Dec 27, 2010 | Audio Players & Recorders
How to program utilitech 1 outlet daily timer
Do you have the Utilitec number?
Add a comment with description of timer I can help.
I own several Utilitec timers.
Following link shows programming for 4 different Utilitec timers;
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Dec 01, 2010 | Day-Timer Hardware & Accessories
Rain Bird sprinkler timer blowing fuses
Disconnect all zone wires and see if timer blows fuses. If not, one of the zone valves is drawing too much amperage.
Oct 02, 2010 | Rain Bird 4 Station Single Program...
How do you program the utilitech 1-outlet daily timer
How do you program the Utilitech Outdoor 6-outlet Stake Timer
Dec 01, 2009 | Day-Timer Hardware & Accessories
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
