Question about Boating
Where can I find manual for a 1988 5 hp sears gamefisher (Force mfg.) outboard ?
2 Suggested Answers
  • 65 Answers
SOURCE: where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
water pump is in the lower end of out drive and there is no t-stat
Posted on May 08, 2009
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
I have a 1979 Sears gamefisher 7.5 hp outboard motor. I replaced the water pump in the gear housing assembly and now i am just trying to reassemble the whole untit back to the motor again. I cannot seem to...
TRY TURNING THE FLYWHEEL TO HELP LINE UP THE SPLINES ...
OR PUT THE LOWER UNIT IN GEAR SO THAT WHEN YOU ROTATE THE PROPELLER THE SHAFT TURNS... THAT SHOULD HELP YOU LINE IT RIGHT UP
HOPE THIS HELPS
Aug 08, 2010 | Boating
I have a 1988 gamefisher outboard motor I need to put a water pump on other than taking the bolts out at the bottom is there any thing else that need to be disconnected before pulling the lower unit thanks...
yes!! there will be a cover in the back of the upper part of unit. you will need to remove this and disconnect the shifter from the lower end.
Jun 20, 2009 | Boating
Where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
May 05, 2009 | Boating
Water circulation (coolant) thru outboard motor
Common problem is the thermostats staying closed. If i remember correctly they should be replaced every year. Water should be spitting out on the upper part of the shaft. Good luck on that fishin'
Apr 25, 2009 | Boating
Boating Logo
35 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
