Question about KTM 2013 125 DUKE
Hi I have a 2013 Ktm duke 125 the stator winding broke not sure why after having it rewired I fitted unit onto bike when I tried to start it just has a winning sound and will not turn moto any ideas
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • KTM Master
  • 47,220 Answers
Hi, Anonymous for this situation I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.motogelnar.cz/manual/KTM/KTM125-200_1999-2003ServiceManual.pdf
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 125 DUKE EU Owner Manual
KTM 125 Duke 2013
KTM Wikipedia
Posted on Apr 22, 2017
  • 11 Answers
SOURCE: stator Resistance
Try adujsting the rev screw on the side of the carb, dont turn it any more than 1/8 at a time, turn it clockwise to increase revs, and anti-clockwise to decrease them
Please rate my help, thanks
Posted on Apr 21, 2009
MakisRC51
  • 408 Answers
SOURCE: Duke 2 loss of power when engine under load
Is the bike at stock condition?
Check the carb and the charging system.
You should measure 13,5-14V at your battery in 3000rpm with your high beams on.
Posted on May 31, 2009
  • 11 Answers
SOURCE: IVE GOT A ktm lc4
haw is your idiol speed is it low . it sounds like the starer cluch is sliping you need to remove it and check it out for were
Posted on Jun 07, 2009
  • 3 Answers
SOURCE: 2005 ktm 450sx not starting
Do u mean checked valve timming? it must be on tdc and both flat edges on cams must be exactly level
Posted on Jun 15, 2009
tabbycat282
  • 56 Answers
SOURCE: yz125 no spark
G'day i am a . YZ 125 j ...lets see now! You could perform these tests yourself.Check your plug CAP,if in doubt replace it with a new one. Take the below ohm figures and see if they match up. Pulse coil: white/blue and white/red= 310 ohms. low speed coil: Green/white and Black/red= 900 ohms. high speed coil: Green/blue and black= 55 ohms. hope this has helped in some way to helping you solve your problem.If it has please leave feed back.Ride hard , see ya,Tabbycat
Posted on Jul 24, 2009
The ignition button wont work
Hi, Ryan before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
Ktm Duke 125 Will Not Start
HELP Starting problem KTM Duke 125
http://www.ktm.com/globalassets/product-manuals-pim-data/dok_bike_bed_13_3211963_en_om__sen__aepi__v1.pdf
Apr 10, 2017 | KTM 2013 125 DUKE
The check engine light came on my KTM duke 125 after I was driving it in the rain what should I do?
Hi, Peleg it should be noted that the reasons your check engine light constant or flashing, will or will not start, turns over or not conditions varies from the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work or event IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
1. Faulty Fuel Pump, fuse or system relay switch.
2. Battery starting to fail due to old age/damage, perform a load test.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
5. Broken wire or worn insulation exposing wire to a ground situation especially inside wire harness at tight bends around fairing brackets, under dash panels, under fuel tanks over cylinder heads etc. Many harnesses are open on the ends that will allow water to enter and accumulate at v-bends.
6. Check for generated fault codes.
Dielectric grease and contact cleaner are your best friends for wire/cable/harness connectors, look for corroded, broken, or loose pins/sockets.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Ktm duke 125 Check Engine
https://drive.google.com/file/d/0B-UgQx8CVp8JemN0Z2FRQnFQLU0/view
KTM 125 DUKE EU Owner Manual KTM DUKE 125 200 2012 Workshop Repair Manual
Dec 04, 2016 | KTM 2013 125 DUKE
Ktm 125 duke won't start when turn ignation on there is just a click
Sounds like you just have a defective battery, pull the battery and have it tested.
Aug 17, 2016 | KTM 2013 125 DUKE
KTM 125 Duke 2011 mil light blinking two long and three short.
You are SOL! Have to take it to the dealer. KTM has not given a list of the fault codes for that bike. That bike also has alot of problems with the computer and going into safe mode.
Apr 06, 2014 | 1998 KTM Duke
KTM Duke 125: dashboard shows "Low oil pressure" but the moto is just back from the garage, and he has certainly enough oil.
Since it was just worked on ... take it back and find out what the problem is. Could be a disconnected or faulty sensor. In any event, since you took it to be repaired, and paid for it, get it repaired. Don't run the bike until this is resolved. Low pressure is DEADLY to a engine.
Feb 07, 2013 | KTM Motorcycles
1996 KTM Duke quit running while riding
ok, your problem could be simple or could be quite involved. First thing to do would be to make sure its not a safety cut out i.e. kill switch on handle bar is set to off or is malfunctioning, side stand down while in gear, no neutral light. Also is the battery good?? A poor battery can cause the bike to have no spark as it can act as a resistor and not allow 12v to flow through the system thus preventing enough current for a spark. If its not that, hears where it can get tricky. It could be a number of other things i.e. If it has an immobilizer factory fitted or via an alarm system, Coil (which is usually not the case), Generator stator and pick ups or worse case a faulty CDI/ECU. You may want to get someone who knows about bikes to take a look. Good Luck
Feb 06, 2018 | 1996 KTM Duke
When is duke 125cc will arive in nepal?how much will it cost
hi check here
http://a2znews.net/ktm-duke-125-bike-review-features-price-price-price-in-india-colors-specifications-mileage-a2znews-net/2010
Nov 26, 2010 | kawasaki Full Suspension Mountain Bike Men
2008 KTM 990 Super Duke added Leo Vince slip on's now bike will not start
Hi, Erideree young ECM's can be very picky about strangers wanting to play with her children, it should be noted that the reasons your FI light stays on constantly or flashes and your bike will or will not start and may turn over or not, these conditions will vary from bike to bike depending on the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work done to the bike or an abnormal event occurrence IE: adding accessories, electrical curiosity/adventures, laying the bike down/crashes, rain storms/bike washings just before FI light issues started can be significant hints/aids into tracking down the gremlin. The newer the bike the more sensitive the ECM becomes and will not let the bike start when aftermarket accessories have been installed without being reprogrammed. That being said the usual suspects are:
3. A discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty safety switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
6. Installation of aftermarket accessories ie. exhaust systems, mufflers, air cleaners, fuel tuners, electrical component etc.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KTM 2003 950 Adventure Repair Manual
https://www.partsfish.com/page/oem-parts-for-ktm
KTM 990 SUPER DUKE 990 SUPER DUKE Owner Manual
KTM 990 Super Duke
KTM Wikipedia
Nov 03, 2017 | 2008 KTM 990 Super duke
My ktm duke had a low battery i fitted a new one and the ignition worked fine but now it dose nothing but bike kick starts
Check your stator and voltage regulator for proper output. Sounds like the battery isn't receiving a charge through the system. You can charge the battery with a trickle charger to verify the battery will take a charge outside the bikes charging system.
Sep 18, 2009 | 2001 KTM 640 Duke 2
Grab bar install
does anyone know of a way of fitting rear grab bars to this bike? CheersJust get a grab belt thing.,
Nov 10, 2008 | 1996 KTM Duke
KTM 2013 125 DUKE Logo
849 people viewed this question
Top KTM Hunting Experts
mark moore
mark moore
Level 1 Expert
Dan Apthorp
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Are you a KTM Hunting Expert? Answer questions, earn points and help others
