MY TRIPAC APU WON'T STAR CONTRAL PANEL STOCK ON STANDBY MODE CHECK FUSE OK THERE IS A GREEN BLINKING LIGTH ON THE INTERFACE BOARD
  • 7 Answers
SOURCE: no power red ligth blinking 6 times
The problem is the thermal fuse. You need to have service bulletin to fix it. I have seen other people have the same issue and it was fixed by getting the SB at agoraquest. It's a step by step guide on replacing the thermal fuse. The member that has the service bulletins is Jehill. He has helped several people with this issue
http://www.agoraquest.com/viewtopic.php?topic=24322&forum=34&start=0&select_page_number=1
It takes about 2 hours but saves over $400 in service repair bills.
Here are some of the people that were helped by this
J/K :-p ......worked like a charm :-) Took me about 2 hours and almost half of that was to go and get a 20" #2 philips screwdriver. A 12" would have worked, but they did not have it. Other than than that, no problems. I paid $220 for the TV, $28 for (2) Thermal Fuses, and $11 for a screwdriver. Now I have a decent 2nd TV :-) Not as good as my KD-34XBR960, but not much is :
Happy
I just got done replacing the thermal fuse as per your SB and all is well again! I, and most importantly the wife, just want to take the time to thank you so much for your help. With your instructions and this site, we have just saved ourselves alot of $$ not just for this time but also if it were to happen again in the future. I am truley grateful for finding this site and just want to say you are THE MAN!!!
pratt31
1 10" screwdriver $12.00
1 Sony Thermal Fuse + shipping $ 8.00
1 membership to agoraquest.com $12.00
Fixing the thermal fuse myself on a TV that was discarded at the curbside
PRICELESS
Posted on Apr 14, 2008
  • 41 Answers
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Posted on Mar 30, 2009
  • 51 Answers
SOURCE: The tv turns off automatically & standby light blinks 4 times
4 blinks is bad backlight inverter. Download the service manual here:
http://rapidshare.com/files/208591107/KDL40S2000_L5_sm.pdf
Posted on Aug 22, 2009
SOURCE: Power/Standby mode blinking, what is the reason?
I have a Denon AVR1708 and a Denon AVR687. Both had this issue and the issue is related to high temperature usage; like if the unit is in an entertainment systems with poor ventilation. I was able to fix both fairly easily. The issue is related to the voltage regulators on the power supply board on the 1708 and the main board on the 687. In my case, I had failures of the -15 volt regulator KIA7915PI. Both I believe were related to high temperatures.
You can get the regulator for as little as 50 cents at some online stores. The job on the 1708 was easy, however, on the 687 it was a bear. It took about 1/2 hour on the 1708 and 2 to 2 1/2 hours on the 687. The component is a lot harder to get to on the 687. The component needs to be unsoldered and removed and the new component soldered in. You will probably have to remove some caps to get go access. Thermal grease should also be applied to the new component.
Posted on Aug 30, 2009
  • 3 Answers
SOURCE: TV off...cant get out of standby mode
Sounds like the connections on the CRT Socket or CRT circuit board. Remove back and check connections.
You could also have buildup on the cathodes of the electron gun (internally) to redimie you must have set in operation and viewing video. Tap the neck of the tube gently while watching for the colors to change until they Stabileize, this is best seen whith the color turned off.
Good Luck
Posted on Feb 12, 2010
TV will not power up, no blinking lamp
hi caps don't have to be swollen to be fault that blinking light means you have no 5 volt standby, you need to check diodes capacitors transistors resistors may be best to look for a tech in your area, hope you get it working
regards
shaun
Jan 25, 2014 | Sony KDF-E60A20 60 in. LCD HDTV
Green ligth com for a few second rex ligth blink for 13 time
Download its service manual. It will have all details to this fault.
Jun 06, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Stanby button blinks
It means the set has either a power supply issue or the standby which is part of it is not working.
some info;
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Jun 03, 2012 | LG 32LX3DC 32 in. LCD HDTV
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
My sony bravia 46" doesnt
hi,
you have to replace the inverter board. If the invereter board overloaded the powers supply, then the tv will go to standby after some time.
ok
Jun 21, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Standby light flashes green and red, the pattern is 11 flashes, is this serious
Submit the TV to an authorised SONY workshop for a quote and a full assessment of the actual problems. This repair could prove expensive/uneconomical, but it is up to you. The quote (and their second opinion) should help.
Here is a list of the problems that might have occurred indicated by the number of blinks:
* Unit is dead, No blinks = Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
* Continuous blink once a second, no pausing = No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
* 1 blink = not used for the self-diagnosis
* 2 blinks = B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
* 3 blinks = B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
* 4 blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
* 5 blinks = AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
* 6 blinks = No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
* 7 blinks = High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
* 8 blinks = Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
* 9 blinks = Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
* 10 blinks = Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
I assume the TV has no picture/sound as a result.
Dec 15, 2010 | Sony KV-36FS12 36" TV
Apu starts fine but no fan no heat and no air conditioning and no 120 volt.
Hi there, Would this be a preheat / comfort pro APU? If so I would start with removing the top cover on the APU. There will be a fuse holder with a 20 amp fuse on the back wall on the left side of the APU above the APU controller. Check and see if the fuse is blown. If it's not then the CCU board under the bunk/ bed isn't seeing power. Either 12v harness or the communication harness both from the APU controller to the CCU board are rubbed on the frame, or the CCU board isn't transferring power properly. The CCU board is under the bunk. There are 4 3/4 bolt's that hold the lid on. Start the APU and look at the board you should have green light's light up. these light's are called input light's. Then chose a function on the driver control panel as in heat, a/c, low or high fan and see if they come on. If the driver control pane are showing the function on look down at the CCU board and see if there are orange light's on. these light's would be your output light's. There's a lot of cause's for this problem if you need further help feel free to ask. Thank's
Nov 08, 2010 | Carrier Heating & Cooling
When i turn tv on green light blinks two or 3 times then goes back to red and never turns on
We need to know what make and model to accurately answer this question, but if you have a Sony, here is the information -
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again. Here is a list of the problems that might have occurred indicated by the number of blinks.
Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Jul 03, 2010 | LG 42PC3D 42 in. Plasma Television
Is it possible to jump start a thermo King Tripac APU without jump starting the Tractor?
it should be if its mounted under the box or on front but your refrigreation compressor needs to be on the box not the truck
Apr 06, 2010 | Heating & Cooling
Aug 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
