My firestick will not update - Televison & Video
Kodi isn't t working what to do
There are various reasons why you Kodi is not working. If you are using kodi on firestick, check out this detailed step by step procedure. Kodi not working on firestick Lets fix it with 3 methods updated 2018
Dec 10, 2017 | Televison & Video
How do i get the firestick on my tv screen..set on hdm1 or hdm2 or ? I don't know how to bring it up on the screen?
The TV remote has a button for that. Input Select or Source or SEL. However simply turning off anything except the firestick should make it work. I presume the firestick came with a remote. Simply turning it off and on from that should do it. Make sure you can see the firestick when you press the buttons.
Oct 21, 2017 | Televison & Video
Can you explain in simple terms that if I buy a fire stick with kodi, does that means it automatically streams various films and music from Amazon or Netflix foc. Does it needs to be jail broken
Why would you buy kodi installed FireStick when you can do it yourself in a few minutes? I mean, OK, you don't have any problem to spend some additional money in buying Kodi preinstalled Fire Stick but what if you get problems later? It is always better to know how to install Kodi on Firestick as it will help you in future too. How to Install Kodi on FireStick
Jul 03, 2017 | Televison & Video
There is no signal on my tv from my firestick
Make sure your firestick is plugged into an outlet. Make sure you change the input settings on your TV to access the firestick output.
May 06, 2017 | Televison & Video
I have accidently wiped KODI off my fire stick how do I get it back?
You can reinstall kodi on firestick with a lot of methods but one of them is given as follow
Similar to other methods, this method too requires you to enable installation from "Unknown sources." Once you do it, follow these steps.
Before these steps
STEP 1: Search FireDL on your Fire Stick.
STEP 2: Install FireDL and Open it.
STEP 3: Type 600003 at the top blank space.
STEP 4: The above code will automatically convert to the Kodi APK URL and download will start without any further actions from your side.
You can then install some great addons and builds to further enhance your experience.
19 Best Kodi Builds To Experience The Colors Of Kodi
Apr 14, 2017 | Amazon Fire TV Stick
I downloaded kodi on my FireStick but it won't install it, how can i fix it
Hey, there are couple of ways to download as well as installing Kodi on Firestick. I am not sure which method you used to download Kodi. I would suggest you download Kodi using ES File Explorer and then it will show install button as soon as download completes.
You can also check this guide - https://www.firesticktricks.com/install-kodi-on-fire-stick.html
If any further issues, please let me know.
Mar 06, 2017 | Televison & Video
My firestick remote will not work
1.Replace batteries.(in remote)
2.Get within 12 inches from firestick.
3.Press and hold home button for 10 seconds.
This should now pair with firestick, and should work
Feb 21, 2017 | Televison & Video
I have a smart TV and currently using DirectTV. I want to get rid of DirectTV to save money. I was told to get a jailbreak Firestick?
It's a good idea to use Jailbroken Amazon Fire Stick as it is quite affordable and also easy to use. It has Kodi TV installed on it and so you get access to a wide range of channels and that too for free of cost.
Due to its small size, it can be easily transported and you are able to enjoy its benefits everywhere with an ease.
There are various sites where you will get the fire sticks. Choose a reliable site and enjoy its premium benefits.
Jan 13, 2017 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
