Had blown fuses now have current to outside unit e1code senville 1200
2 Suggested Answers
  • 11 Answers
SOURCE: the fan unit outside isnt running. is it a blown fuse perhaps?
There is no fuse box. Open the cover and see if the wires goingto fan are not burnt.(Power off the AC before opening cover). If not, you need to check it live with a voltmeter to see if its getting voltage. If the voltage are on motor wires, motor is burnt.
Posted on Apr 27, 2009
Senville mini split heat pump is stuck in defrost mode
Did you find a solution to this? as I now have the same problem???
Dec 31, 2014 | Senville 18000Btu 21 Seer 12.5 EER...
Senville mini split displays a "defrost" symbol????
It's a heat pump and that is how they work. But it shouldn't be cycling so much unless you live in Minnesota? The colder it is outside the more chance that the outside coil will freeze so it will go into defrost. It may be low on charge or have leak as well. Call a tech to verify.
Apr 13, 2014 | Senville 18000 BTU Ductless Air...
It looks like it has not current
Make sure the power is correctly plugged in. If all are okay outside the unit, the problem lies inside the unit. If a line of black Squares blinks on the display, it is a capacitor that is blown. If nothing happens on the display, the fuse is blown. No user serviceable parts on the power supply unit. Professional technitian service required.
Mar 15, 2011 | Samsung SF-330 Plain Paper Inkjet Fax
E4 error on Senville Ductless Heat Pump
I am Roger Duncan.
I have the same error on my Senville unit. What board did you replace, the inside board or one of the outside boards?
I really would appreciate an answer. I have been working with Gt World since July and I still have no a/c or heat.
Jun 29, 2009 | Dehumidifiers
Directional light not working
check your flasher and replace it's only about $5.00 it's in with your fuse box the bigger (usually) silver round object
Dec 12, 2008 | 2004 Hyundai Elantra
Senville Mini Split Error Code
The E4 light on your system is saying there is a commiuntion problem between the inside unit and the outside heatpump unit.Make sure there are no loose wires and you wired it properly,The S wire is the commiuntion link wire make sure it is a solid run between both units.I had the same problem with my system and it was the s wire not making a good connection.
Nov 03, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
