Question about Kitchen Ranges
My duel fuel range master toledo is tripping the electric, when either of the 2 ovens or the grill are turned on, the stove has just been installed after being in storage, there is no damp
Krazytech
  • 725 Answers
SOURCE: Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Posted on Aug 25, 2008
grandadfixer
  • 99 Answers
SOURCE: Door handles on rangemaster toledo 110 duel fuel
Yes this is easy to do.We can supply bits if required.
Posted on Oct 23, 2008
FitzOriginal
  • 842 Answers
SOURCE: range master toledo 90
I would follow these requirements if I were you:
The cooker must be connected to the correct electrical supply as stated on the voltage label on the cooker (This is obvious so far!). It should be connected through a suitable cooker control unit incorporating a double pole switch having a contact separation of at least 3mm in all poles (This means one of those big red switches with "COOKER" written on them). The cooker must NOT be connected to an ordinary domestic power point. The cable size used should be between 6mm squared and 10mm squared twin and earth. Where the installation is protected by a 30 milliamp sensitivity residual current device (RCD Breaker), the combined use of your cooker and other domestic appliances may occasionally cause nuisance tripping. In these instances, the cooker circuit may need to be protected by fitting a 100 milliamp device. This work should be carried out by a qualified electrician.
Posted on Mar 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: Maytag Performa Electric Range (PER1510) tripped circuit breaker.
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Posted on Aug 23, 2009
heatman101
  • 43501 Answers
SOURCE: KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
No electricity going into my rangemaster classic 110 duel fuel
Check your breaker panel or fuse box to see if something is tripped. If you have a breaker panel, try flipping the stove breaker off all the way even if it looks like it is still on and then turn it back on and check stove. If you still have no power then you probably better call an electrician.
Aug 13, 2014 | Rangemaster Classic 110 (Dual Fuel) Dual...
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
I need to reset the clock for summertime but cant! Stoves rangemaster
push the button on the front of the stove that says "clock" and then turn the dial (same one you use for timer and oven temp) till you get the time you want, then LEAVE IT ALONE and it will set itself. Don't touch anything once you have the time set with the knob.
Mar 31, 2010 | Rangemaster Toledo 90 (Dual Fuel) Dual...
We had a power cut and can now not get either oven to work , the light in the hood and the grill and hotplate are still fine - it is classic 110 dual fuel is there aome kind of trip switch i can reset?
it is the timer. i take it that the display is blinking and no current time is seen? hold the 2 buttons on the left down together for a few secs, now the display will show 12:00 set it to the true time and you are good to go
Mar 19, 2010 | Rangemaster Professional 110 (Duel Fuel)...
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
Need a duel fuel range
We love ours have had it for two years. We have the 48" Dual fuel with the grill on top. Model ZDP48N6RH2SS.
The only issue we had to adjust to is the btu's (stove top flame) are so high and there is designated simmer burner or low btu burner.
The grill is excellent especially in the winter but you have to follow the instructions. First time use we didn't let it heat up long enough. Patience - it's worth it.
That's for our model from 2006.
YOu must be sure to get a strong enough range hood for the range you buy.
Dec 24, 2008 | GE Monogram ZDP48L4GHSS Dual Fuel...
Aug 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
