Question about Pool & Spa
I need a diagram to wire a Leeson motor A6C34XC28A to 115 volt
    Top Expert:
  • 45,036 Answers
The wiring diagram may have to be requested directly from Leeson.
Posted on Apr 15, 2017
I need to wire a SP2607x10
look on motor should be a diagram pump is wired from factory for 240 volts if wiring 120 volts you have to chenge the brown and white wire see diagram then black goes to F1 white goes to F2 where white wire is
Jul 08, 2014 | Hayward SUPERPUMP 2.0 HP, 115/230V
New leeson 3 hp motor for my tablesaw has very little torque, and is less powerful than my old 1hp craftsman motor. What could the problem be?
If the motor is a 115/230 volt motor and is running on 115 volts but the wiring is configured for 230 volt operation, the motor will be weak.
Apr 05, 2014 | Leeson Table Saw Motor - 113627
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
I have Delco Model 2J2424r1, frame 56R, Series A84, phase 3 electric motor. What is the wiring diagram to run it under 230VAC?
If it has 9 leads and is a 240/480 volt motor the 1and 7 go to line 1. the 2 and 8 leads go to line 2 and the 3 and 9 leads go to line 3. the 4 5 and 6 leads are hooked together with a wire nut. To reverse rotation simply reverse any 2 of the line leads.. Prairie Dog........
Jun 15, 2011 | Leeson Reversible Electric Motor 3/4 HP
I need a wiring diagram for a farm duty 6k714k
It is generally located on the nameplate of the motor or inside the wiring housing where the outside power is brought in. These motors are usually convertible from 115 to 230 volt by merely switching a couple of wiring connections inside the wiring housing. If you can do so, 230 volt operation is much preferred due to the high speed start-up available and you can use wiring 1/2 the size required for 115 volt operation. Good luck!
Jun 05, 2010 | Dayton Audio Dayton 6K138 CapacitorStart
I need a diagram to wire it to a saw
should be a wiring diagram on the wiring cover.
Oct 25, 2009 | Leeson Reversible Electric Motor 3/4 HP
I want to re wire an electric motor for low volt
Look on the name plate. If it says under 'volts' 120/240 that means it's dual voltage and you can use either voltage to run.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Electric 1hp 1800RPM 56C Frame 12 Volts Dc...
Pool & Spa Logo
47 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
