Question about Yamaha Boating
No power to front 80amp fuse in motor fuse box to Yamaha outboard vz200tlra and fuse is good.
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 23 Answers
SOURCE: my yamaha 130hp outboard starts and runs good but
The carbs need to be cleaned.There is a high speed jet in the carb that is more than likely stopped up. Jim OMC retired mech.
Posted on Jul 07, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
  • 95 Answers
SOURCE: outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Posted on Mar 13, 2010
Hi, can you tell me the year model of my Yamaha 40hp outboard? Serial number 452214.
Search Results
Yamaha Outboard Serial Number Location and Model Identification ...
https://www.perfprotech.com/.../yamaha-outboards/yamaha-outboard-serial-number-l... The Yamaha Outboard Motor MODEL, PRE-FIX and SERIAL NUMBER are stamped on a plate attached to the transom clamp bracket. When ordering parts and/or accessories from our Yamaha OEM Online Parts Catalog it's important to properly identify the exact model you are dealing with.
Yamaha Year Models - Hunts Marine
https://www.huntsmarine.com.au/pages/yamaha-year-models This Yamaha outboard year model chart will only work for Asia Pacific distributed engines. If you have a Yamaha engine that has been bought in from America or E. ... For Asia Pacific engines your year model code is found on the bottom right hand corner of your serial number decal. It will be a single letter as per the ...
Decoding Yamaha Outboard Motor Model Number and Manufacture ...
www.murrayyachtsales.com/decoding-yamaha-outboard-motor-model-number-and-... Dec 30, 2015 - Decoding Yamaha Outboard Motor Model Number and Manufacture Date (MFG Date)
Yamaha Outboard Serial Number Lookup
uvgb.you4k.top/ By Darnell Zacharias. DOWNLOAD Yamaha 60HP (60 HP) Repair Manual 1984-2009 Outboards 8.8. By Michael Hornby. HOT. How To Decode A Suzuki Outboard Serial Number 8.4. By Ralap James. Mako 261 Center Console Boat For Sale at Unreserved Auction (Inv.3368) 7.1. By Aldrich Child. yamaha 40hp 2 stroke ...
Outboard Spares YAMAHA Model Year IDENTIFICATION CODES ' eBay
www.ebay.com/gds/Outboard-Spares-YAMAHA-Model-Year...CODES-/.../g.html Outboard Spares Yamaha Outboard Model Year Identification Details needed for ordering outboard spares parts On the Serial Number Plate on most Yamaha Outboards it will be in this format 6E9-L-675634 The...
Jan 15, 2018 | Yamaha Boating
I cannot start the motor or raise the tilt and trim. Have power to the starter solenoid. have powere to the starter
check the control box , use multi metre and check the trim button and ignition key ! check main harness socket on the engine for corrosion or breaks in the wires !
Apr 11, 2014 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
I had my lights and tilt working before realizing I had a kill switch at ignition. got my motor starting and running good now but now I have no tilt working or my lights. wondering are they a kill switch...
First check fuse box, look for one that is blown. also look for a loose or disconnected wire . It also may be that the lights and tilt are on the same circuit . if it is a blown fuse, replace it with the correct same fuse. Also check that connections at the battery are tight.
Jan 05, 2018 | Boating
Yamaha 200hp 2001 manual
  1. Fuel
    • A common problem with an easy solution, Yamaha boat engine trouble could arise due to inadequate levels of fuel or engine oil. All Yamaha outboards take unleaded gasoline as a main fuel source with a pump octane rating of 86 or higher. The type of engine oil varies according to motor size and can be found in the "Specifications" section of a particular outboard's owner's manual (See Resources).
    Electrical
    • Problems with the electrical system can also prevent a Yamaha outboard's engine from working correctly. Troubleshoot the electrical system, first removing the main fuse that's located underneath the electrical panel on any electric-starting outboard. If the connection at the center of the fuse is broken, it must be replaced by a fuse of the same amperage. The battery should also be removed, cleaned and fully charged when troubleshooting the electrical system.
    Spark Plugs
    • Owners should also remove and inspect the spark plugs during the troubleshooting process. If the insulator tip of any plug is burned, that spark plug should be replaced. The number and type of spark plug depends on the specific outboard. Additionally, owners should ensure that each spark plug gap is set to the width stipulated in the owner's manual (see Resources).
Jan 20, 2013 | Motorcycles
1998 isuzu trooper need wiring diagram for charging system with a3.5 li5ter motor
1998 trooper new alternator and still not charging and alternator bench tested good,
Check main 80 amp fuse in engine compartment and also check fuses in inside fuse box, there two in that one. first is engine fuse 15amp and the 10amp gauge fuse,
Here is the wiring diagram for the charging system as you asked for , also check connections, follow battery wire off the back of alternator make sure connections are good , that wire runs to engine fuse box and that is one fuse that i said to check it is 80amp, hope this is helpful good day9_30_2012_10_15_05_pm.gif
Sep 30, 2012 | Cars & Trucks
How to remove glow plug fuse from holder
there are two 10mm nuts securing the fuse box, remove those and then push the 80amp fuse downwards out of the fuse box (you'll see a clip to the side of the 80amp fuse) once you've slid it out from the bottom of the fuse box you'll see it the wire terminals bolted to the fuse. undo the 10mm nuts and remove. easy as!
Aug 04, 2012 | 1989 Toyota 4Runner
95 yamaha 90 outboard 2 stroke keeps blowing fuses
Motor should run with blown fuse,maybe faulty ign switch or short in harness plugs
Oct 12, 2011 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
48 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
