Gas heater in mobile home.low flame lights but will not turn up to high when adjusted.
    Novelist:
    Champion:
  • 259 Answers
Need new gas valve.
Posted on Apr 16, 2017
bigg t
  • 640 Answers
SOURCE: Gas Oven Flame Constantly on High
I belive that the thermostat to the oven isnt working properly.The t-stat bulb sits inside the oven on the wall and this is what senses the temp in the oven.If its out of place or the t-stat is bad the oven will just keep heating.hope this helps let me know.HAPPY HOLIDAYS!!
Posted on Dec 03, 2007
SOURCE: gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Posted on Sep 25, 2008
  • 160 Answers
SOURCE: Gas oven
Its the flame failure device faulty (FFD)
Posted on Feb 22, 2009
  • 77 Answers
SOURCE: dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Posted on Jan 22, 2010
gcken
  • 140 Answers
SOURCE: It only gives low flame upon starting and cannot
close your air vent on the burners it will increase the height of the flame
Posted on Apr 04, 2010
I installed a Mr Heater 45,000btu heater in my garage, when I turn it on to fire, it fires for a moment, I get about a 3 inch flame for a moment and then it goes out. What do I need to do?
clean the flame sencor first check connections on flame sencor , check you have gas to heater check limits high and low jump then out one at a time see if it lights , or check pressure switch if fitted jump this out and check tubes to it
Jan 20, 2011 | Mr. Heater Natural Gas Garage Heater -...
Adjust pilot light
Adjust? What do you mean? The flame relationship to the T-couple? Or is the flame too low?
Low flame can be adjusted on some gas valves but mostly it requires special tools and knowledge of the gas valve. Most times it's a sign the GV is going.
Mar 01, 2009 | Water Heaters
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Pilot light lights
air gas mix racio to high on air.
Jan 03, 2009 | Endless Summer 153100 Open Flame Patio...
Simmer is to hot
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Oct 31, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
