Question about Garden
Where do you put oil in the transmission of a john dehere 115 lawn tractor
tripletauto
  • 1450 Answers
SOURCE: John Deere LT190 Lawn Tractor transmission problem
is it hydrostatic drive? if so you probably need to change filter and fluid
Posted on Oct 01, 2008
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
  • 12776 Answers
SOURCE: John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Posted on Sep 29, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
Were do you check the transmission fluid on a john deere lx173 lawn tractor?
i am not familiar with John Deere but most lawn tractors dont have a way to check the fluid they are sealed.
Sep 04, 2017 | John Deere Garden
John Deere 430 lawn tractor hydrostatic transmission will not work in forward or reverse even with no weight on the axle. New filter and oil did not fix. What should I check next?
Some have a procedure for "burping" air from the hydraulic system. Changing engine oil and filter won't affect it- independent system.
Apr 02, 2017 | John Deere Garden
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
125 electrical drawings
Here's the link and I'm sure you will get the solution of your problem.
John Deere 102 115 125 135 145 155C 190C Lawn Garden Tractor Technical...
Sep 14, 2016 | John Deere Garden
Transmission oil foaming and pushing out of dipstick tube during normal transmission operation. Transmission has been serviced - oil & filter replaced with OEM components.
Has the suction filter been serviced? And what transmission oil have you used? Is it John Deere hydraulic oil or hydraulic/transmission oil? Does the tractor have a loader?
Dec 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Oct 14, 2009 | John Deere Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
