Question about Command Computers & Internet
Unable to download files, folders,pictures to SDCard. No command that allows me to copy files to card
File manager has stopped working
    An user who is expert in 3 categories / brands.
  • 575 Answers
You can always reformat it.
Posted on Apr 15, 2017
    New Friend:
    Problem Solver:
  • 10 Answers
First you have to copy file ( picture, document or video) by open the internal storage folder.. Then open the sdcard that folder where you want to paste it.
  • 40 Answers
SOURCE: error copying file or folder
You can always reformat it. If you plug the mp3 player into your computer and right click on the icon in the MY COMPUTER window, and click on FORMAT. It should come to a new window and click on start format. Your fixer, Wild2DMaxx
Posted on Jan 25, 2007
  • 2985 Answers
SOURCE: download pictures to file folder
Remove the software [Control Panel/Add remove software/ Casio.
Restart Computer.
Plug camera in
Make sure it is set to Upload.
Windows does the rest
Posted on Oct 22, 2007
SOURCE: unable to write to file
I had the same problem and fixed mine without re installation. Even though the error does not indicate it very well, the application could not write to the destination. The EPSON Scan application has a destination in two places. One under configuration, in my case, correct. However, a more buried location, next to the Scan button, press the arrow to edit more settings. There, you will find another destination, in my case, incorrect ( a folder that did not exist). Change the setting to a folder that does exist, it should work. Check out my fix here, detailed with pictures. Thank you. Hope this helps someone.
Posted on Nov 17, 2008
SOURCE: DCIM folder turned to a file after windows scandisk fixed a reported problem
Hi, I don't know if you'll get this message, but it's worth a shot. I am having the same problem and I wanted to see if you ever found out how to get your pictures back. I don't have the same camera as you but the same thing happened to me. I'm on Windows 7 though now. Thanks
Posted on May 25, 2010
  • 76 Answers
ok so i dont know what causes the DCIM folder to read as a file but you can access it thru the command prompt if you need help doing that just reply and i will be happy to help. let me know how you go.
Posted on Feb 04, 2011
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
Jul 10, 2016 | Tablets & eReaders
Have downloaded cd file but unable to download pictures via usb to pc
What make and model camera? If it uses a memory card of some type, consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( ).
Apr 20, 2014 | Cameras
How to download picture from tablet to sd card?
usually you can find your sdcard under /sdcard or /mnt/sdcard use a file manager such as OI FileManger (assuming Android tablet here)
If it's windows based, then your SDCard will show up like any other disk on the system.
Jan 13, 2014 | Computers & Internet
Internal memory is full idont know how to clear the memory
When you put USB connection to your PC, use Explorer, or some other file manager (Total Commander, Free Commander ...) for going to your memory card (like you are going to some memory stick). Move your picture file to another folder on computer for saving. You can copy, move, delete files from your camera. It is the same as from memory stick.
On menu of camera, you must have option for deleting (or formating) camera memory. I don't like this hand removing. You have better control with computer...
Aug 24, 2011 | Kodak EasyShare C330 Digital Camera
How to download in my pc?
When you download a file-such as a program, update, game, video, or document-you transfer it from the Internet to your computer.
When you download files using Download Manager, they're automatically saved in the Downloads folder. This folder is usually located on the drive where Windows is installed (for example, C:\users\your name\downloads). For information about managing your downloads and changing where they are saved, see Using Download Manager in Internet Explorer
If you're saving a file, you can choose to save it to a particular folder. If you don't select a folder yourself, some files are automatically saved to a folder associated with the file type. For example, if you right-click a picture on a web page, and then choose Save Picture As, it will be saved to the Pictures folder.
Open Download Manager
  1. ? to open Internet Explorer.
  2. Click the Tools button getcontent.aspx?assetid=448ef968-d58a-43a2-b0cc-f396f4024f2c&documentset=en-us&prod=win700&market=us , and then click View downloads.
Right-click a file, and then click this
To do this
Delete File
Delete the file from the computer.
Copy download link
Copy the link you used to download the file. You can paste the link, and then save it or send it to someone else.
Go to download webpage
Open the webpage where you downloaded the file.
Open containing folder
Open the file's location on the computer.
Report that this file is unsafe
Open a SmartScreen webpage where you can report malware (malicious software).
Rerun security checks on this file
Run all security checks, including SmartScreen filter, on the file.
This information is in the "help files" in your computer.
Apr 17, 2011 | Toshiba Computers & Internet
How do you download video clips from a Canon FS100 camcorder?
the easier way its to go on the actual folder and copy /paste ...but ...the actual way to select it just like a picture..and then download....I believe you used only the automatic download until now...but if you cancel that will either open the folder prompt to ask you what to do ...just like you insert a cd...and there select open folder...and copy manually ...or the manager import from device ..and there look for the folders(browse) where the videos are is usually a different one on the card..
...also if you cancel the initial will find the camera storage (SDcard) into the My computer a removable device ......act with it as any other moving from folder to folder...beware if you select cut ...this will remove from the card permanently ...the file
Jul 16, 2009 | Canon FS100 Flash Media Camcorder
Camera will not read SD card
1.) Mount your camera
2.) Open your dcim folder in your camera
3.) In whatever file browser you're using (Explorer, Finder, Nautilus, etc) enable show hidden files.
4.) Remove .thumbnails folder
5.) Be sure to empty trash
See if that works.
Nov 03, 2008 | HTC G1
Memory card
You need to go to your file manager/my documents/my picture. Once there then you can move/copy your pictures to your memory card.
Press "menu" -> "file" -> copy/move to. It will then allow you to select the folder you want your pictures to be moved to. Move to "Storage Card" and click 'done.That should move/copy your pictures.
Select the files you want(one or more files can be selected).
Jun 13, 2008 | Motorola Mobility Q9m Smartphone
u copy that to PC and try to open with windows picture viewer then format the Memory stick then re use u will get ur files as well as u can use ur memory stick , mail me ur memory stick result
Feb 15, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Computers & Internet Logo
41 people viewed this question
Top Command Computers & Internet Experts
Lawrence Oravetz
J the Guru
Level 1 Expert
Are you a Command Computer and Internet Expert? Answer questions, earn points and help others
