Question about Tablets & eReaders
Keep getting message that file manager has stopped working. Also, unable to download files to SD CARD - I'm not given any command to do this. Need help - Tablet is M97 Matsunichi
Tablets is a disappointment.
  • 102 Answers
SOURCE: Model # rct6378w2 ... an rca tablet ... i cannot
Have you tried this? http://rcatablets.com/sites/default/files/Tablet%20recovery%20mode%20to%20wipe%20data%20Android%204.1.pdf
Posted on Jun 18, 2014
  • 31 Answers
SOURCE: can,t play files from external sd
Some devices do not like certain brands of SD cards. I once had a tablet that would not read my 32GB card, but my phone would. Try a different brand of SD card and see if the issue is resolved.
Posted on Jul 19, 2014
  • 6702 Answers
SOURCE: How do set the trio stealth to use an external SD card
I show you one of the many links about using an SD card on an Android tablet or phone:
How to install Android apps to your SD card by default fixedByVonnie
Posted on Jan 11, 2015
FRMT
  • 16 Answers
SOURCE: How do I remove the latest KitKat update from my tablet? I have android 4.4.2 version
Which tablet do you have and is it boot locked?
in most cases you can't downgrade you device unless you have rooted it and or unlocked the boot loader (this does void your warranty if you do either of them)
Posted on Jan 12, 2015
  • 131 Answers
SOURCE: How can I retrieve my pictures back that I had taken with my tablet camera ? For some odd reason my tablet keeps erasing me pictures .
You can have them back by Photo recovery process as your photos has been erased so the process would be this only. Also check your SD OR memory card may be storage space it not there for new addons. I suggest can suggest you services for picture recovery who can also guide you for the further precautions to be taken after retrieval. Digital Photo Recovery services to recover lost deleted or formatted...
Posted on Jan 30, 2015
How do I transfer pitchers and video from my next book 8 coudcor tablet to my pixplus micro SD 32gb card l am new to all of this?
You need to download a file manager on the tablet insert the sd card in the tablet and use file manager to copy files from tablet to sd card hope this helps
Jan 17, 2018 | Tablets & eReaders
What do I have to do to download from tablet to SD card
Insert SD card into your tab and make sure it is detected and accessible.
Download your files.
Open file manager on your tab and navigate to Download folder. Click to open.
Hold on the file(s) downloaded one after the other to select.
Top right of your screen or bottom right of your screen you will observe a set of 3 dots aligned on top of each other (i.e. if an options menu has not popped open); click on these.
Options to copy, share or a symbol like a Y turned on its side will become visible; select and navigate your way to SD card (still within file manager); click to open and then Paste/copy here.
A video tutorial would have been appropriate. Working on this please
Oct 11, 2017 | Tablets & eReaders
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
Jul 10, 2016 | Tablets & eReaders
File manager saying LOST DIR for my SD card
Your cel phone download path is the internal storage, modify the download path to SD card or move files to sd to gain space.
May 13, 2016 | Tablets & eReaders
How can I add my own pdf files to the sd card
I have a couple of android tablets. To transfer files to the microSD card, I plug the USB cable into my laptop where the files are and make sure it is *connected as a media device* in Settings or the drop-down menu in the Kit Kat operating system. Then I use Windows File Manager to choose and copy files to the SD card. Windows File Manager displays the android device and shows the internal storage and the microSD card storage. Be sure to open the SD card storage by clicking on it and then create a folder called Downloads if there isn't one already there by that name and then copy your .pdf files into that folder. If you wish to create a sub-filed in the Downloads folder called PDF to keep things better organized you can do that as well.
Good luck.
Mar 08, 2015 | Tablets & eReaders
How do i use the extra space and memory card on my tablet?
You need to format it as NTFS instead of FAT32. FAT32 will throw up warnings when you attempt to copy over anything over a few gigabytes. Plus, NTFS is more stable and secure. Try that first.
Is this happening when you try to copy over large files or a large number of files? I'm curious to know what the specific issue is. Could you tell me if you can copy anything over at all? Have you tried the SD card in another device?
Either way, check the formatting to make sure it's NTFS. Good luck!
Jan 02, 2015 | Nextbook Tablets & eReaders
Transfer data from galaxy 10.1 note to sd ext storeage
Go to the play store and download a file management app. Use the app to move the files. OR, connect to a PC and manually move the files to the SD card
Dec 27, 2017 | Samsung Galaxy Note 10.1
Hi, 1. How to transfer/copy bootable XP files onto SD card and then boot up Toshiba Portege M205 from the SD card? 2. Is it possible to made an image of my Windows XP CD on SD card? Regards Tad
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
  • Asus Eee PC (Of course!!)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your 3epc from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
Jan 27, 2011 | Toshiba Portege M205-S810 Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
