Question about Maytag MZD2766GES Side by Side Refrigerator
My Maytag side by side MZd2766ges cool side door has a 1/2 gap at the bottom of the door. Is this an adjustment or new weather stripping issue?
    Problem Solver:
  • 9 Answers
Slide the gasket back or have it replaced.
Posted on Jul 27, 2009
    President:
  • 2,976 Answers
It could be both. It also could be twisted from putting large heavy bottles, high in the door.
Posted on Jul 24, 2009
How do i fix my fridge that stopped working?
To aid in troubleshooting, the link below may be of help:
MAYTAG MAYTAG REFRIGERATION Parts Model MZD2766GES Sears PartsDirect
You may have a failed defrost heater.
Jun 27, 2015 | Maytag MZD2766GES Side by Side...
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
1995 Saturn SC2 leaks when it rains - Water comes in from passenger side (upper frame) and somewhere in the trunk. Put silicone gel on the foam stripping, did not stop the water. Replace the door and trunk...
You can actually find NOS weatherstripping for old Saturns at getsaturn parts.com. At least I was able to buy a new one for a 94 last year. It is a website for a Maryland dealer who sells at below regular cost. I have had 5 saturns and they never sold me a bad or wrong part. You could also look around on ebay, but what you would find there is another used leaky one.
http://www.trademotion.com/splash/index.cfm?siteid=214643
Jul 25, 2010 | 1995 Saturn Sc
Refrigerator is not cooling like it should
we had the same problem turn it off for 24 hours ice build up in the back makes this happen
Jun 16, 2009 | Maytag MZD2766GES Side by Side...
Door gasket gap
Hi, Try rolling up a piece of paper towel and place it behind the door gasket to stretch it. It might take a few days to stretch.
I hope this helps.
Please let me know if I can assist you further.
Vic
May 30, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
After many repairs to my maytag mzd2766ges, my fridge side cools for a while and then it stops until a new repairs
If either door is open, the airflow will be wrong. Do you see a lot of "snow" or frost building up at the bottom of the freezer rear wall?
Do you hear a fan running in the freezer compartment?
Where are your controls set?
Is the fan back by the compressor running?
Have you checked the air duct at the bottom behind the lower crisper drawers?
The main reason for this type of problem is that the (evaporator) coils below the fan would be iced up.
So, i need you to do this,
1.unscrew the back panels on the freezer side and note whether the evaporator coils were all iced up.
2. If it is iced up, then defrost the coils and then replace the defrost board in the refrigerator.
Regrigerator will be back to normal . Defrost board is located on top of refrigertor side underneath the temp control unit.
Easy repair once you remove the temp control cover. Unscrew the defrost board and plug new connection in.
Post your comments about how things turned up.
Thanx for using fixya,
Cheers.
you can also mail your comments: mailmeswami@yahoo.co.in
Sep 27, 2008 | Maytag MZD2766GES Side by Side...
MZD2766GES: How do I level the doors?
The door needs to be level, or the whole side of refrigerator. Pull off black strip at bottom front, there should be screws on either side to level the fridge. goodluck
Nov 09, 2007 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
182 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
