Question about Vizio Televison & Video
Does a vizio model 320ar have any fuse that would keep it from working
Vizio Model E420i-AO not working. Back light Leds keep blinking on and off.
It sounds like you have at least one LED lamp that is shorted and sending the backlight PS into shut down
Nov 02, 2017 | Vizio Televison & Video
My vizio subwoofer is not working. no sound coming from it. model SB3821-C6
Could be an internal fuse failure. Or power supply problem. Or the main amp on it has gone.
Aug 07, 2016 | Vizio Audio Players & Recorders
I have a.e220mv model vizio and everything works the picture just keeps flickering
The manual says to check all connections to make sure they are tight. And if you are using an antenna try moving it. It does not state any other options
Aug 12, 2015 | Vizio Televison & Video
I have a vizio model number vp422hdtv10a and it keeps blowing a fuse everytime i plug it in. do i need a new power supply?
This would confirm a power board componet failure , I would suggest you change that out for the fix. I recommend shop or I sure wish you best of luck with your repair, do ask that you please leave some feedback, ratings for your free advise. Regards Rulds2008
Aug 18, 2011 | Vizio L32 32 in. LCD HDTV
Watching program, heard a pop snap and unit lost all power. Even the vizio logo on front panel is dead.
Seems like a filter capacitor has arced and blown a fuse or a couple of fuses. Open the back cover and check the main fuses. If you replace with new fuses and the TV keeps blowing the fuses then replace the bridge rectifier and main filter capacitor. A local repair shop could take care of this very quickly for you. Its not an expensive repair...
Nov 12, 2010 | Vizio VL370M LCD TV
No Picture just sound from Toshiba 37hl17
IT is the Y Sustainer board blowing fuses. IT has 2 fuses. I have worked on severl of this model and the Y Sustainer board goes bad and blows the fuses.
Feb 22, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
