Question about Sony Computers & Internet
Is it possible to use a Sony KDL-S26A12U as a monitor for a computer running windows 10? Does one need to install the correct driver? all advice gratefully received. Dave Cormie
  • 5158 Answers
SOURCE: can I run or install windows server 2008 on Intel 945 GCNL Motherboard based computer
check the intel website for drivers for that board
Posted on Sep 09, 2008
  • 72 Answers
SOURCE: window came off track and fell into door need to
All you need to do first is remove the screws that hold the door handle on there should be three, next gently pop the panlr off useing a screw driver do not break the wires that control the windows and door locking system and then if you need to replace the entire window track do so but if you do not need to do not if you do it is easy to do so just remove the nuts at the botom of your door , they hold the window track in place and then remove the three bolts that hold the motor in place and then next gently pull the window up and then remove the traco after you have removed the window and reverse the process when putting new track in.
Posted on Sep 13, 2009
SOURCE: instructions for Sony dvd RMT-D248P
Some info (like how to re-programme for a tv) included in the HD/DVD recorder instructions:
Posted on Nov 11, 2009
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
  • 22306 Answers
SOURCE: Hi, I have a peugeot 307 (2003 model) hatch back
take teh door panel off and have a look i think you need a new mechanism ,sounds like the cables and the outer cables are loose in the mechanism,nice economical car though better than a cadalac doing 11mpg ,if they had to pay europeon prices for fuel then they would think twice in america
Posted on Apr 30, 2010
Sony vaio pcg-7g2n sound driver for windows 7
Sony vaio pcg-7g2n Driver Download offers an overview of the drivers are installed, as well as links to be able to bring to download for Windows 7, Windows 8, and Windows 10.
When installing drivers for Sony VAIO important to follow the correct sequence of installing these drivers in order to avoid problems with the work of the function keys: volume+Fn, brightness+Fn, input switching+Fn, and others.
Drivers Download
Jan 01, 2014 | Sony Computers & Internet
Looking for windows 7 driver for SDM-HS95P monitor tq
(If this does not explain enough for your issue, please take a few minutes to clarify the specific problem regarding this specific monitor style and Windows 7).
Being that this is an older style monitor, drivers may not be available for a newer operating system, (such as Windows 7). Here is the link to the sony drivers download page:
The newest supported operating system is Windows XP.
The generic monitor driver for windows 7 should pick up this monitor without any need for specific driver installation. Just try plugging it in and it should register automatically.
Jun 10, 2011 | Sony SDM-HS95P/B 19" LCD Monitor
Sony Bravia KDL-52XBR TV - have sound but no picture
Hi mstevens376,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 31, 2011 | Sony KDL-52XBR4 LCD Monitor
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Dec 29, 2010 | Princeton Digital VL173 Monitor
I have conntected my kdl 52 xbr6 to several computers most recently to a sony viao and an HP with HDMI output, and the TV produces the message output not these same computers work fine...
some of the newer tv's require drivers to be able to become a monitor if that's not what it was originally meant to be, try going to the sony site then under your model download the drivers.
Apr 08, 2010 | Sony BRAVIA KDL-52XBR6 LCD TV
Monitor blinking
A possible solution may be with respect to the wrong set up of screen refresh rate.
One method is to use another monitor to set up your system for default VGA to stabalise the video card output to the common standard.
Next switch monitors to your LG and run the installation CDROM or if you do not have an installation CDROM allow your system to detect it and set up a windows default driver with a low refresh rate. When its stabalised get the correct driver from the LG website.
Jun 13, 2009 | LG L1915S 19" LCD Monitor
Screen goes black with white horizontal line.
WHEN does this problem occur? Does it ONLY happen after the computer loads Windows (or another OS), or does it happen as soon as you turn the monitor on? We really need more information before we can provide specific advice or suggestions... IF this happens as soon as you turn the monitor on, switch it with a different monitor. If the problem goes away, the original monitor is defective, and probably not worth the cost of repairing it. If the problem ONLY happens after you load Windows, boot the system into Safe Mode (press the F8 key during bootup until you see the menu which allows you to select Safe Mode), then reboot and see if the problem has been resolved; simply booting into Safe Mode, then rebooting the system into Windows MIGHT solve this WITHOUT requiring you to change any system settings... IF the problem remains in Windows AFTER you've booted into Safe Mode AND rebooted back to Windows, the videocard driver might be corrupted. In that case, you'll have to reinstall the vidcard driver to correct this problem... If all else fails, it IS possible that the videocard itself is defective; if installing an updated driver doesn't work, try swapping the videocard with a different one. BE SURE to uninstall the OLD videodriver, and install the proper one for the new videocard; if you don't install the correct driver, you could create MORE problems than you have right now...
Mar 30, 2007 | Mitsubishi DP930-BK (Black) 19 in.CRT...
Sony hmd-a400 monitor
Next time you get it running, right click my computer>properties>hardware tab>device manager and look for your monitor on the 'Monitors' '+' sign and right click>delete. Also check 'Display adapter' see if the correct driver is displayed. Re- boot and let Windows re-install monitor driver(it should list it as 'Sony')
Nov 30, 2006 | Sony HMD A400/L (Blue, Silver) 19 in.CRT...
Computers & Internet Logo
32 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
