Question about Garden
How to hook throottle links on a techumseh H607550 6R ser 82790
How do you adjust speed on sears Lawn Mower 917.374358
there should be a tab on the throottle plate with a spring attached to itbeen it slowly out to increase speed
Aug 14, 2014 | Sears Garden
Can put throottle spring back in stihl chopsaw s410
It connects to the operator presence lever on top of the rear handle
Feb 02, 2014 | Garden
HOW TO CLEAN DRITY THROOTTLE BODY IN A 04 CHEVY TRAILBLAZER
Remove the air intake tubes to expose the throttle body and hose it down real good with about 2 cans throttlebody and carb cleaner or brake parts cleaner non clorinated use 1 can whil engine is off and the other with engine running but dont spray so much at a time you kill the engine
Oct 06, 2012 | 2004 Chevrolet TrailBlazer
What engine is used to replace oh 160 tecumseh on miller welder
It is a 16 horsepower engine. Techumseh ceased production in Dec 2008 and liquidated the small enegine and Peerless groups.
The issue is what does the PTO end of the crankshaft look like? Straight shaft? not common. If tapered, more common. If tapered, that limits options greatly too.
If the shaft is 1 inch diameter, a 340 CC Honda single has some possibilities, if you have the 1.125 inch shaft, you are up in the 600 CC range twins. Northern Tool does carry them, as well as other brands like Briggs, Kohler, or "Power Horse" which appears on the surface anyway to have the Techumseh castings.
If it is a matter of just no spark, a new Magneto should rememdy that unless the magnets fell off the flywheel. There are aftermarket sources for the magnetos for electronic ignition. There may even be a piston and ring kit for oversize bores too. There may still be some NOS Techumseh parts as well. While it may seem expensive to rebuild the engine, it may boil down to the most cost effective repair. Not many shops will do an overhaul these days though, so time has to be factored in there as well. If you have tool truck stop by on a regular basis he can usually tell you who to visit for the overhaul.
There are other possibilities too, but the tapered shaft limits them greatly.
Jan 22, 2012 | Miller Welding Tools
The 3 prong plug that plugs into the wall has three wires at the end and need to know where do i hook those up too. its a kenmore dryer model #110-64852-400. the ser # is mr2206786
The following link explains how to correctly install a 220 VAC applaince cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
There is a difference in how the 3-wire and 4-wire configurations are terminated. Follow the wire color codes under the 3-wire configuration.
If you have any questions, please post back and let me know. I hope this helps you.
Jan 14, 2010 | Dryers
Usb.2.0-ser
The Drivers can be downloaded
http://rs220.rapidshare.com/files/147263019/HL-340.EXE
See thread here
http://www.davesdrivers.com/forum/showthread.php?tid=895
Aug 20, 2008 | Computers & Internet
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
