Question about General Dryers
Unable to banal even 240 v output on general 15000 one leg only about 80 volts
joboo1
  • 257 Answers
SOURCE: Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
Posted on Feb 08, 2009
nitrospawn
  • 290 Answers
SOURCE: 240 volt supply to inverter is ok but have not got
IT IS POSSIBLE THAT THE INVERTER POWER TRANSISTORS ARE BAD OR INVERTER CONT ACTORS ARE NOT SWITCHING
Posted on Feb 25, 2010
  • 905 Answers
SOURCE: holnda ax 800 generator does not supply 240 volt
Your generator was not designed, nor capable of, supplying 240vac outputs. 120volt only.
Page 30 (of 37) in specifactions
http://www.hondapowerequipment.com/pdf/manuals/31ZA7000.pdf
Posted on Jun 12, 2010
heatman101
  • 43501 Answers
SOURCE: I am working with a Dayton 2YU39. The name plates
Here's what I think but you will have to check it out...
The fan motor in the 39 heater is a 120V fan there fore it cannot be hooked to the 240 which potentially could have the high (wild) leg as one of the fan legs...
The 240V 36 unit probably has a 240v fan motor....
Now if you were to make sure that the leg that fed the motor was a 120V to ground leg then you will be okay...
Hope you understand where I was going with this...
heatman101
Posted on Oct 27, 2010
  • 1033 Answers
SOURCE: Condenser unit will not run. has 240 volt at
Hello, check the tstat wiring going to the unit for any breaks in or if it has come loose between the indoor unit and outdoor unit. Also, chevk if you are getting voltage from tje control board between the y and c terminal, if not the control board is bad. Last thing to check is remove tstat and jump the y and r wires there if this starts the unit then you have a bad tstat.
Posted on Apr 30, 2011
I purchased a generac 22 kw 3 phase 120/240 volt generator. I was surprised to find that it had a wild leg. Can i change the leads on the stator output to eliminate the high leg and get straight 120/208...
This unit is wired 120-240V 3 phase Delta. if you are using on it 120/208V 3 phase application it will need to be re-tapped. If you are using it in a home 120-240V single phase it will need re-tapping, Do NOT just use 2 legs, as this will cause rotor imbalance and wear out the rotor bearings, and odd ball currents to flow. If there are 12 leads coming off the stator it can be reconnected. If not you are stuck with it, except by using a transformer
Dec 15, 2013 | Generac Generator QT02224JNAX QuietSource...
Not getting hot
first make sure theres 240 volts at the dryer plug in ,if not then try resetting your circuit breaker ( or fuses ) if its electrically heated (not by gas) and is plugged into a 240 volt receptacle as even though the breaker may not show its tripped by the little orange window on the breaker it can lose one phase of power ( 120 volts) and still turn but it needs both phases to operate the 240 volt heating element,if you lose one leg of power ( 120 volts ) either the drum will turn or the timer will run (but not both ) because each of these parts only operate on 120 volts or one leg of the 240 volts
Nov 11, 2012 | Kenmore Dryers
Kenmore electric dryer #11066512694 no heat & keeps running
Heat circuit also runs through timer and motor
Oct 26, 2017 | Kenmore Dryers
Back up generator 240 volt output is off balance?
So there is a problem. Where are you measuring voltage?
Say there is L1 - N - L2. Line1 to Neutral is 120 volts, Line2 to Neutral is also 120 volts, Line1 to Line2 is 240 volts. N or Neutral ( the grounded conductor ) is center tap between line 1 and 2.
With this system, the N wire carries the unbalanced load in amperes .
Now we are talking of L1 and L2 and amperes. When L1 and L2 are conducting 10 amperes each, N carries 0 amperes, Line1 and L2 are balanced. When L1 carries 10 amperes and L2 carries 5 amperes, Line1 N carries 5 amperes, the difference of L1 and L2. This is normal.
When there is a problem with a loose connection on N, there is a resistance and will not carry the unbalanced load normally, the voltages will Chang's under load, the problem will worsen with time, a fire hazard, connected loads may burn up from excessive voltage or not work at all.
Bottom line: Make sure the N line ( white wire ) is tight at every connection and inspect for overheating damage. You may have to open the generator connections panel to check there too.
Aug 06, 2017 | Electrical Supplies
I am working with a Dayton 2YU39. The name plates states that it has to be powered by 208 volt system. There's a 3-phase panel and a single-phase panel. The 3-pahse panel L1 to ground is 118 volts. L2 is a...
heatman101
Oct 27, 2010 | Dayton 2YU44 Electric Heater
I am installing a brand new nordyne furance I am not getting power to the 24v transformer the 240 wires going to the transformer are connected to the same leg. What leg is the wires suppose to be connected...
The have to be connected to both legs of the 240 volts, one wire on each leg. You have to have 240 volts going to the high voltage side of transformer.
Feb 21, 2010 | Heating & Cooling
My kenmore 80 series dryer won't heat but everything else works fine I cleaned the vent duct of all lint [ there was alot ] and checked the electrical conections
Had similiar problem once and it turned out to be one leg of the 240 volt
supply was dead. The drum motor only needs one leg (120V) to run, but the Heating elements require both legs (240v). Make sure you have 240V at the recep.
Nov 27, 2009 | Kenmore Dryers
Where do i connect load wires to 240 volt baseboard heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Oct 27, 2009 | Dayton G73 Utility Heater
Dryer keeps tripping the fuse. I replaced the Moisture Sensor control last year, but now it's doing it again. Could soemthing else be damaging the control
check the neutral connection from input power all the way thru the unit, if theres a bad connection the 120 volts will use the other 120 volt connection to make ground and you get what they call a voltage-divider circuit and say the motor is on one leg and the moisture sensor control is on the other leg,the motor will draw only about 80 volts and the sensor will get the imbalance of the 240 volts or about 160 volts and will not last.
Sep 25, 2009 | Dryers
Low heat 100 degrees
either the cycling or hi-limit switch are bad or the element is open or the neutral wire can burn open or you could have lost one leg of power to the dryer so instead of 240 volts its running on 120 volts,the motor and timer run on 120 volts even though they are normally on opposite sides of the 240 volt circuits,chk the power to the unit first for 240 volts its the easiest test
Aug 25, 2009 | Dryers
Dryers Logo
27 people viewed this question
Top General Dryers Experts
Tim Whalen
Sal De
Are you a General Dryer Expert? Answer questions, earn points and help others
