Question about Parallel Office Equipment & Supplies
Please I bought ir2200 and I connected it with a parallel cable when I send data from my desktop d copier indicates receiving but no print out .pls help me .
  • 1326 Answers
SOURCE: Canon iR2200 Copier
E003 is a fixing unit error code. Have you been having power problems? Is this the first time it showed up? If so you need to reset the code in service mode..
Resetting Code: Press "*" additional fun.
Then at the same time "2&8" Then the "*", then touch "Copier", "Funca", "CLR", "ERA", then "OK"... then turn the main power off then on.
Posted on Jul 10, 2008
  • 876 Answers
SOURCE: scanner driver for canon ir2200
Here is your link to download that driver:
Posted on Aug 01, 2008
SOURCE: Vista connection -USB to Parallel Port Cable
Yes. Your product is supported. Drivers for HP printers are included with the Microsoft Windows Vista Operating System
HP has a Windows Vista driver solution available for your product. This driver will enable your product's basic functions to work. HP is committed to providing the best experience for HP products in the Windows Vista operating environment. You can conveniently find this driver in your Windows Vista operating system, today. At this time the driver will only be available on the Windows Vista operating system through the “Add a Printer�? wizard there is an alternative for this
remove all the drivers from add and remove program then
click start, then "run" type regedit, hit enter Registry Editor will open up.
Make backup of you registry, then on left side drill down to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
and check if you have "USB Monitor" key defined - If yes, you have different problem, this will not solve your problem. If not - right click on "Monitors" then click on new/key and name new key "USB Monitor" and then open this new key and on right side of the Registry editor under the (Default) right click select New - String Value this will create REG_SZ type value and name it "Driver" then double click to open it and in value data type "usbmon.dll"
Do the same thing to "Local Port" and "Standard TCP/IP Port" keys if you don't have them under Monitors key but you have them listed under AutorunsDisabled key. Then close registry editor, and restart, go to add printer/ local printer
Posted on Aug 12, 2008
  • 98 Answers
SOURCE: best way to network a HP LaserJet 4L with 2-wire gateway?
If you want to hook up the printer directly to your wireless gateway, you could get a print server. They are made for usb or parallel printers and run about $40 to $70 for a single printer hookup. Run the software that comes w/ it to create network settings and for installation.
Posted on Feb 12, 2009
  • 89 Answers
SOURCE: iR2200 as a printer/scanner - wireless network configuration
You need to hook an ethernet cable into your network. You could get a wireless router to extend another one and connect via ethernet into that if you prefer.
For setting up network settings, do you have the Network Guide?
Go to page 2-11 and follow the instructions there.
You can click the DHCP icon and hopefully you'll get an IP address etc. (you may have to restart using switch on right hand side of copier to turn off, wait a while then turn back on). Once you have an IP address click on the DHCP icon again to make sure it's not filled in with black and save settings.
IP address must be in same range as other devices on your network e.g 192.168.1.x or 192.168.0.x (only specify a number for x between 1 and 254, must not be used by another device). Subnet mask must be same as for other devices. It's probably Canon Network ScanGear 2.21 (don't get the colour version) can be found on the Canon website (google it). Instructions for scanning are in the manual included with the download.
Posted on Jan 14, 2010
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
May 02, 2013 | Office Equipment & Supplies
General Printer Troubleshooting
Printer does not have power indicator<br />First, make sure that the printer is on. When a printer is on it should have some light (usually green) indicating it's receiving power and is on.<br />If you do not have any indicator light make sure the printer is connected to a working power outlet by verifying each end of the power cable. Next, press the printer power button.<br />If after following the above steps your printer still cannot get a power status indicator it's likely you're encountering a serious printer issue and we suggest contacting the printer manufacturer for additional steps and instructions on repair or replacement.<br /><br />Cables not connected properly<br />Your printer should have two cables connected to it. The power cable and the data cable, the power cable should have already been verified as being connected if your printer has a power indicator light as mentioned above. Make sure the data cable (parallel cable or USB cable) is also connected from the printer to the computer.<br /><br />Printer error (orange or blinking light)<br />After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.<br />Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.<br /><br />No paper or paper jam<br />Without paper your printer will not be able to print. Make sure you have paper in the paper loaded into the printer paper cartridge or tray. Next, verify that no printer paper is jammed or partially fed into the printer. If you have one or more pieces of paper stuck in the printer these will need to be manually removed before the printer will print again.<br /><br />Inkjet printer ink related issues<br />Often when you're encountering an ink related issue you're printer status indicator light (mentioned above) should be flashing. If this is not occurring you may want to skip to the next section. However, if you've recently inserted a new ink cartridge you may want to try the below suggestions.<br /><br /> * Replacing ink cartridges and printer not working.<br /><br />Printer self tests<br />Most printers have a way of printing a test page. This page allows you to determine if the printer is physically working or not. This test is usually accomplished by holding down a series of keys. If you are not sure if your printer has this feature or how to perform it refer to your manual or visit your printer manufacturers web site.<br />In addition to testing the printer using the printer self-test Microsoft Windows users can also perform a software self-test to determine if their computer is able to see the printer and it's able to print. Follow the below steps to perform this test.<br />Microsoft Windows 98, 2000, ME, XP, 2003, and Vista users<br /><br /> 1. Click Start, Settings, and open Control Panel.<br /> 2. Double-click the Printers or Printers and Fax icon.<br /> 3. Right-click on the Printer you wish to test and click Properties. If you do not see your printer listed your printer is not installed.<br /> 4. In the Printers Properties window click the Print Test Page button.<br /> 5. If the printer is able to print a test page, you're printer is installed and setup properly. However, if you're unable to print in other programs it's possible that the program you're attempting to print from has issues.<br /><br />Older versions of Windows with older printers<br />If you are running an older printer and MS-DOS, Windows 3.x, Windows 95, Windows 98, or Windows NT, you can also attempt the below software test.<br /><br />Get to a MS-DOS prompt or Windows command line<br />Get to the root directory - Type: cd\<br />Reroute dir to printer - Type: dir &gt; lpt1<br /><br />The above should take the directory listing and print to the printer. If this does not print, refer to your operating system troubleshooting section. Extra Note: This will not paper feed, therefore press your FF or PP, or manually eject the paper.<br /><br />Printer drivers<br />If your printer does not have any flashing lights and is connected properly it's possible you may be encountering a driver related issue. We suggest visiting our printer driver listing, which links to all major printer manufacturer driver pages and downloading the latest printer drivers for your printer.<br /><br />Parallel (LPT) printers<br />If the printer you're connecting to the computer is an LPT (parallel port) printer we also suggest verifying the below suggestions if your printer is not working.<br />Parallel port in CMOS<br /> 1. Enter the computers CMOS setup.<br /> 2. Once in CMOS verify that your parallel port is enabled or installed.<br /> 3. Next, verify the printer or parallel port mode. This option will often have several different modes. If your parallel port is set to ECP mode, we suggest trying a different mode.<br /><br />Other parallel device<br />If you have a parallel printer with other parallel devices such as a parallel scanner or zip drive, temporarily disconnect these devices to verify they are not causing your issue.
on May 09, 2011 | Office Equipment & Supplies
Not printing
I need to know the model number please. Not printing? I also need to know is it connected with a usb cable or an ethernet cable or a parallel cable. Please state if after you send a print job, does it try to print or does your computer say it never did print? Otherwise your question is vague and quite broad in the fix it world, please elaborate.
Nov 29, 2011 | HP Office Equipment & Supplies
EtherFast Print Server manual
Other gurus might correct me, but I don't think this can easily be done. You are dealing with "parallel" data with the HP and "serial" data with the PC. If your HP has cards you can change, then conversion to serial data is relatively simple, otherwise...
Mar 29, 2010 | Linksys EtherFast 10/100 (epsx3/uk) Print...
Sharp AR-168D will not print
you should change your printer data cable or fix correctly with printer port.
Jul 30, 2009 | Sharp AR-168D Copier
I have reconnected my HP PSC 1315 to my printer, however, I cannot get the printer to work. Can you please help me? The printer will not do anything. I have received a print test after I installed the...
Hi melovesjags:
Try these steps.
Does the product
print from the
Connect the parallel
cable or USB cable to the
product and the
computer. Use a wordprocessing
application to
send a print job to the
The cable is not
connected correctly.
Reconnect the cable.
An incorrect printer driver
is selected.
Select the correct printer driver.
Other devices are
connected to the parallel
or USB port.
Disconnect the other devices and try again
to print.
There is an LPT port
driver problem.
Reset the computer port settings. See your
computer user guide for instructions.
The formatter has failed. Replace the formatter.
Hope these help
Jul 06, 2009 | HP PSC 1315 All-In-One InkJet Printer
Got error of "PC cannot send datga to printer. Please check power
my printer, I got error of "PC cannot send data to printer. Please check power and printer cable connections and retry printing". Please help me.
Apr 02, 2009 | Sharp AL-1642CS Copier
Canon ImageRunner 2200 printing
the parrellel port is used also to updated machine soft ware.... if you do not have the print bootrom installed it will not print sorry
Dec 22, 2008 | Canon imageRUNNER 2200
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
26 people viewed this question
Top Parallel Office Equipment & Supplies Experts
Are you a Parallel Office Equipment and Supply Expert? Answer questions, earn points and help others
