Question about Samsung Microwave Ovens
E-83 Error Code Samsung Microwave? - Samsung Microwave Ovens
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
Code for samsung microwave
Can you please clarify what the main problem is so we can give you exact solution? I'm sorry I didn't quite understand what you mean. Thanks!
Oct 10, 2008 | Microwave Ovens
Samsung microwave# smh9187w-x error code 5e-how to repair?
Error code for a shorted membrane keypad switch. Manufacturer suggests unplugging the unit for an extended period of time to see if the control panel will clear the code. If not, then you probably have a defective switch.
Jul 22, 2014 | Samsung SMH7178STD Microwave Oven
Error code se micro wave samsung?
Error code indicates a shorted membrane keypad switch. Manufacturer suggests you unplug the oven for an extended period of time to see if it will clear the code itself. If not, you may actually have a bad switch.
Jul 10, 2014 | Samsung SMH7178STD Microwave Oven
Samsung SE error code
Followed Timm Eckenroth's suggestions in a post from 08/02/2012
and it fixed the problem on my Samsung same model as his.I was a little skeptical at first ,followed all his steps ,put it back together ,prayed about it and it worked..Thanks to Timm and the ourLord..
Nov 12, 2012 | Samsung SMH9187ST Microwave Oven
Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
Jun 14, 2012 | Samsung SMH8165W Microwave Oven
E41 and does not work
If your microwave is displaying an error code cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker.
If the above suggestion does not work,and the error code returns, your microwave will require service.
Aug 19, 2011 | Samsung MW1080STA Microwave Oven
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven.  If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
Oct 21, 2007 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
48 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
